Z homing with bltouch
Posted by acca
March 11, 2020 12:46PM
Hello,
I'm making a homemade printer using marlin
I have a bltouch and a z endstop switch (approx at z=155mm)
When I launch homing, the z endstop switch is used, is that the normal behaviour ?
I'd like the bltouch to be used, is that possible ? Safe ?
Thanks
Re: Z homing with bltouch
March 11, 2020 12:50PM
Yes - the easiest way to do this is to remove the Z end stop switch and plug the BLTouch into the Z min end stop connector.
Then enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN and Z_SAFE_HOMING.
March 11, 2020 01:01PM
And is that possible to keep the switch for security ?
March 11, 2020 08:12PM
No, but unless you have ENDSTOPS_ALWAYS_ON_DEFAULT enabled the endstop switches are ignored except for homing anyway.
March 12, 2020 05:07PM
My bad
I was using homedir 1 instead of -1 for z axis
Now I have the switch connected to zmax endstop and bltouch to zmin endstop and used for homing
Thanks
