Trouble setting up Marilin4Due: MINTEMP triggered, system stopped! Heater_ID
Posted by HenrikMet
March 17, 2020 10:58AM
So I'm building a printer by myself and I'm stuck in setting it up.
I use:
- Arduino Due, RADDS, RAPS128, Hexagon Hotend with 100k EPCOS thermistor ( I don't have other thermistors)
- Arduino IDE, Marlin4Due, Pronterface, MacOS 10.13.6
I upload the frimware to arduino from Arduino IDE. I have selected correct ports etc in Arduino IDE and in Pronterface. When i click "connect" in Proterface i get the following message. I don't see anything else and i can't adjust or test anything(pic attached) :
Connecting...
start
Printer is now online.
echo:Marlin 1.0.3 dev
echo: Last Updated: 2015-06-00 12:00 | Author: (none, default config)
Compiled: Mar 13 2020
echo: Free Memory: 90348 PlannerBufferBytes: 1344
echo:Hardcoded Default Settings Loaded
echo: Steps per unit:
echo: M92 X384.00 Y533.00 Z960.00 E1980.00
echo:Maximum feedrates (mm/s):
echo: M203 X200.00 Y200.00 Z2.00 E20.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X3000 Y3000 Z100 E10000
echo:Accelerations: P=printing, R=retract and T=travel
echo: M204 P3000.00 R3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X10.00 Z0.30 E2.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo: PID settings:
echo: M301 P22.20 I1.08 D114.00 C1.00
echo:Filament settings: Disabled
First start for temperature finished.
Error: MINTEMP triggered, system stopped! Heater_ID: 0
[ERROR] Error: MINTEMP triggered, system stopped! Heater_ID: 0
Error: Printer halted. kill() called!
[ERROR] Error: Printer halted. kill() called!
I have tested the thermistor from the connectors that connect to RADDS and it gives me 116kOhm.
I have baudrate on 25000 on both ends.
Can anyone help me to resolve the problem or understand it? What might cause it if the thermistor is allright?
In Marlin4Due i have:
- no edits in the software. Only basic firmware configuration. These are the temperature settings. You can not change TEMP_SENSOR_0 to 0. I have tried having TEMP_SENSOR_0 1 and TEMP_SENSOR_1 to 1. I have also tried "#define HEATER_0_MINTEMP 1" "#define HEATER_0_MINTEMP 25" etc:
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 0
// This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Actual temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
open | download - Pronterface.png (284.8 KB)
Re: Trouble setting up Marilin4Due: MINTEMP triggered, system stopped! Heater_ID
March 17, 2020 01:18PM
"Marlin 1.0.3 dev" This is a dinosaur
Real marlin has supported due for ages.
Please consider Marlin 2.
But the most obvious thing is you have the thirmistor plugged into the wrong place. (or pins files is pointing to wrong place and not looking at the thermistor)
Or it could be a dead analog pin..
