Get zeto position Gcode in Marlin
Posted by Jori
March 30, 2020 09:57AM
I was wondering whether there is a G-code in Marlin that does the same or something similar like the old M117 'Get zero position' command in FiveD? Or whether the old code is still available somewhere?
I want to be able to more my printhead to a point on the build plate and have it report back the number of seps/units from that point to the home position of the X and Y axis.
Hope someone can help out.
Re: Get zeto position Gcode in Marlin
March 30, 2020 10:12AM
M114 reports current position in marlin. in mm from 0,0
And wow, FiveD, thats going back a bit...
March 30, 2020 10:15AM
Does that work when moving the head by hand with motors disabled or only when moving using the jog controls?
March 30, 2020 11:03AM
only with jog. there is zero feedback from stepper motors. You would need additional hardware such as a positional encoder and the firmware to understand that.
March 30, 2020 01:15PM
My plan was to make it count the steps back to the endstops to measure the distance. If I understand correctly that is how M117 worked in FiveD.
March 31, 2020 01:03AM
You should also be aware that moving steppers by hand produces electricity, This can damage stepper drivers.
