ramps rebooting after homing during printing
Posted by vishal_wazir_singh
April 03, 2020 01:49PM
Hi Friends,
I am very new to 3d printing ,however i have managed to build my 3d printer using ramps 1.4 and marlin 2.0 firmware , I am using a 8 mm threaded rod on all axis and not using core xy . My problem is that with using prontface all the axis move fine , and perfectly , and accurate also . the nozzle and the bed heat properly , the extruder motor also works fine , but when i try to print some gcode file made in slic3r the machine homes fine all the axis , heats the extruder and bed , but makes a lot of noise when the motors move and finally before printing it reboots and the exturder fan also switches off and the reprap discount controller shows that it reboots.
Please advise what could be the problem.
Thanks in Advance.....
Re: ramps rebooting after homing during printing
April 03, 2020 08:22PM
you need to set you max feed rates to the max the machine can do. Otherwise gcode will try and move faster than the machine can move
Pronterface applies the feed rates on the screen to manual moves.
