Effector crashes into X tower after Delta Calibration
Posted by jonawald
May 05, 2020 05:33PM
I recently rebuilt my printer with a new Board, new stepper drivers and new Firmware. Now, when I go to do Delta calibration to set up printer for first time, calibration fails by crashing into X tower.
Everything seems to go good to start off with. It does the center probe, then does probes around the edge of the bed and goes back to the middle for a probe. Its after this step where instead of homing all the axis, it homes only the X and crashes the carriage into the X tower. Homeing works well otherwise.
Here is a video of this behaviour. I did make a test print, and everything else worked except for the bed not being quite where it should be for first layer. Everything else is working.
Here is a Google Drive link to my Zipped configuration.
Edited 1 time(s). Last edit at 05/05/2020 05:33PM by jonawald.
Re: Effector crashes into X tower after Delta Calibration
May 06, 2020 04:48PM
So nobody has ideas for me?
May 06, 2020 10:36PM
I changed to Marlin 2.0.x not bugfix. Did not make a difference for me. I can't believe I'm the only one who has run into this problem.
