MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 12, 2020 12:28PM |
Re: MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 13, 2020 12:51AM |
Admin Registered: 13 years ago Posts: 7,000 |
/** * Set this option to one of the following (or the board's defaults apply): * * LCD - Use the SD drive in the external LCD controller. * ONBOARD - Use the SD drive on the control board. (No SD_DETECT_PIN. M21 to init.) * CUSTOM_CABLE - Use a custom cable to access the SD (as defined in a pins file). * * :[ 'LCD', 'ONBOARD', 'CUSTOM_CABLE' ] */ //#define SDCARD_CONNECTION LCDSo you probably want to set
Re: MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 15, 2020 11:50AM |
Re: MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 16, 2020 12:10PM |
Re: MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 16, 2020 12:17PM |
Re: MKS SBASE 1.3 Marlin 2.0 RRDSC SD Card not work May 17, 2020 03:55AM |
