Hi there,
I built P3steel few years ago and it works like a charm.
The firmware is also few years old and i know i should update.
I will, when i have time to figure out all the steps/mm and endstop positions, etc..
My current problem is that i need to set bed temperature to 110C, but i had originally set a 100C limit in the Marlin firmware.
Because still have some issues with ABS warping in larger prints. I can usually print smaller ABS well at the center of the bed using 100C temperature.
I tried using the display menu and set bed temp to 110C, but printer halted at 100C, because the limit is hardcoded in the firmware.
Is there a way to override bed temperature limit?
I don't have the original Marlin files anymore as they went when my laptop went. It would have been easier that way...
