POWER LOSS RECOVERY error May 23, 2020 02:21PM |
#define POWER_LOSS_RECOVERY #if ENABLED(POWER_LOSS_RECOVERY) #define BACKUP_POWER_SUPPLY // Backup power / UPS to move the steppers on power loss #define POWER_LOSS_ZRAISE 20 // (mm) Z axis raise on resume (on power loss with UPS) #define POWER_LOSS_PIN 31 // Pin to detect power loss #define POWER_LOSS_STATE HIGH // State of pin indicating power loss #define POWER_LOSS_PULL pulldown // Set pullup / pulldown as appropriate #define POWER_LOSS_PURGE_LEN 20 // (mm) Length of filament to purge on resume #define POWER_LOSS_RETRACT_LEN 10 // (mm) Length of filament to retract on fail. Requires backup power. // Without a POWER_LOSS_PIN the following option helps reduce wear on the SD card, // especially with "vase mode" printing. Set too high and vases cannot be continued. #define POWER_LOSS_MIN_Z_CHANGE 0.05 // (mm) Minimum Z change before saving power-loss data #endif
Re: POWER LOSS RECOVERY error May 24, 2020 04:45AM |
