ABL Fail Bilinear. May 25, 2020 04:16PM |
Bilinear Leveling Grid: 0 1 2 3 4 5 6 7 8 9 0 +0.958 +0.715 +0.882 +0.785 +1.005 +1.120 +1.217 +1.760 +1.327 +1.465 1 +0.515 +0.285 +0.455 +0.502 +0.640 +0.717 +0.790 +0.927 +0.993 +1.065 2 -0.193 -0.038 -0.083 +0.175 +0.203 +0.345 +0.467 +0.502 +0.637 +0.705 3 -0.433 -0.387 -0.187 -0.085 +0.042 +0.115 +0.190 +0.237 +0.400 +0.450 4 -0.683 -0.550 -0.200 -0.433 -0.195 -0.073 +0.140 -0.015 +0.160 +0.272 5 -0.750 -0.657 -0.490 -0.400 -0.290 -0.225 -0.088 +0.020 +0.082 +0.162 6 -0.755 -0.665 -0.538 -0.480 -0.300 -0.245 -0.143 -0.045 +0.015 +0.157 7 -0.278 -0.580 -0.435 -0.370 -0.257 -0.115 -0.005 +0.015 +0.097 +0.197 8 -0.138 -0.407 -0.243 -0.157 -0.075 +0.020 +0.108 +0.162 +0.252 +0.385 9 +0.097 -0.153 -0.058 -0.103 +0.722 +0.410 +0.015 +0.833 +0.510 +0.595 G29 uncorrected Z:5.80 corrected Z:5.20 current_position= X150.00 Y347.50 Z5.20 : sync_plan_position <<< G29
>>> G29 L20 R500 F20 B300 V3 SENDING:G29 L20 R500 F20 B300 V3 current_position= X150.00 Y347.50 Z5.20 : >>> G29 Machine Type: Cartesian Probe: FIX_MOUNTED_PROBE Probe Offset X0.00 Y-47.50 Z-0.20 (Middle-Front & Below Nozzle) Auto Bed Leveling: BILINEAR (enabled) ABL Adjustment Z+0.595 G29 Auto Bed Leveling current_position= X150.00 Y347.50 Z5.20 : Leveling ON current_position= X150.00 Y347.50 Z5.80 : ...Now OFF current_position= X150.00 Y347.50 Z5.80 : sync_plan_position current_position= X150.00 Y347.50 Z5.80 : Probe::set_deployed deploy: 1 Probe::move_z(10.00) >>> do_blocking_move_to X150.00 Y347.50 Z10.20 <<< do_blocking_move_to >>> do_blocking_move_to X150.00 Y347.50 Z10.20 <<< do_blocking_move_to reset_bed_level Probing mesh point 1/100. >>> Probe::probe_at_point(500.00, 20.00, raise, 3, probe_relative) current_position= X150.00 Y347.50 Z10.20 : >>> do_blocking_move_to X500.00 Y67.50 Z10.20 <<< do_blocking_move_to echo:busy: processing echo:busy: processing current_position= X500.00 Y67.50 Z10.20 : Probe::set_deployed deploy: 1 current_position= X500.00 Y67.50 Z10.20 : >>> Probe::run_z_probe current_position= X500.00 Y67.50 Z10.20 : >>> Probe::probe_down_to_z >>> do_blocking_move_to X500.00 Y67.50 Z-10.00 <<< do_blocking_move_to echo:busy: processing current_position= X500.00 Y67.50 Z2.34 : sync_plan_position current_position= X500.00 Y67.50 Z2.34 : <<< Probe::probe_down_to_z SLOW Probe fail! current_position= X500.00 Y67.50 Z2.34 : <<< run_z_probe current_position= X500.00 Y67.50 Z2.34 : Probe::set_deployed deploy: 0 >>> do_blocking_move_to X500.00 Y67.50 Z2.34 <<< do_blocking_move_to Errorrobing Failed [ERROR] Errorrobing Failed <<< Probe::probe_at_point current_position= X500.00 Y67.50 Z2.34 : Probe::set_deployed deploy: 0 current_position= X500.00 Y67.50 Z2.34 : > probing complete <<< G29
SENDING:G29 P3 current_position= X500.00 Y67.50 Z2.34 : >>> G29 Machine Type: Cartesian Probe: FIX_MOUNTED_PROBE Probe Offset X0.00 Y-47.50 Z-0.20 (Middle-Front & Below Nozzle) Auto Bed Leveling: BILINEAR (disabled) current_position= X500.00 Y67.50 Z2.34 : Probe::set_deployed deploy: 1 Probe::move_z(10.00) >>> do_blocking_move_to X500.00 Y67.50 Z10.20 <<< do_blocking_move_to >>> do_blocking_move_to X500.00 Y67.50 Z10.20 <<< do_blocking_move_to reset_bed_level >>> Probe::probe_at_point(538.00, 2.00, raise, 0, probe_relative) current_position= X500.00 Y67.50 Z10.20 : >>> do_blocking_move_to X538.00 Y49.50 Z10.20 <<< do_blocking_move_to current_position= X538.00 Y49.50 Z10.20 : Probe::set_deployed deploy: 1 current_position= X538.00 Y49.50 Z10.20 : >>> Probe::run_z_probe current_position= X538.00 Y49.50 Z10.20 : >>> Probe::probe_down_to_z >>> do_blocking_move_to X538.00 Y49.50 Z-10.00 <<< do_blocking_move_to echo:busy: processing current_position= X538.00 Y49.50 Z2.52 : sync_plan_position current_position= X538.00 Y49.50 Z2.52 : <<< Probe::probe_down_to_z SLOW Probe fail! current_position= X538.00 Y49.50 Z2.52 : <<< run_z_probe current_position= X538.00 Y49.50 Z2.52 : Probe::set_deployed deploy: 0 >>> do_blocking_move_to X538.00 Y49.50 Z2.52 <<< do_blocking_move_to Errorrobing Failed [ERROR] Errorrobing Failed <<< Probe::probe_at_point current_position= X538.00 Y49.50 Z2.52 : Probe::set_deployed deploy: 0 current_position= X538.00 Y49.50 Z2.52 : > probing complete <<< G29
Re: ABL Fail Bilinear. August 03, 2020 08:55AM |
