I'm working with SKR1.3 and FYSETC 12864 v2.1 display (neopixel version) and found out that having this display enabled, will result in having all the neopixel set up limited to pin EXPA1_05_PIN.
What I mean is, once the display is enabled, it's no longer possible to use neopixel CASE_LIGHT nor NEOPIXEL_LED, everything is ruled by display setting and no other setting can be done.
This is pitty because neopixel has so much potential and it would be cool to have them for other functions besides display setting.
Does anybody know if many neopixel "instances" can be performed in Marlin 2.X?
I'd like to add neopixel for printer status, either under case light option or simply neopixel led using and independant pin different from the one that controls display light.
I also tried to wire the printer status LEDs to the same display pin with the unlucky situation that display LEDs are wired RGB and neopixel ring is wired GRB, so green and red are swapped out.
Any ideas?
Thanks!
