If you watch the temp you notice it jumps up and down a bit.
The final jump is from 231 to 263!
I suspect a damaged ADC on the controller. perhaps a non functioning missing bit.
In your firmware enable #define SHOW_TEMP_ADC_VALUES and AUTO_REPORT_TEMPERATURES
Start up a terminal package at correct baud rate and send M155 S1 (report temperature and ADC values every second)
If you use pronterface you need to enable Settings|Debug Communication to see the temperatures
the log will look something like (this eg im not heating up.. just a cold room)
SENT: M105
RECV: ok T:8.31 /0.00 (1000.69) @:0
RECV: T:8.25 /0.00 (1000.75) @:0
RECV: T:8.06 /0.00 (1000.94) @:0
SENT: M105
RECV: ok T:8.19 /0.00 (1000.81) @:0
RECV: T:8.44 /0.00 (1000.56) @:0
SENT: M105
RECV: ok T:8.25 /0.00 (1000.75) @:0
RECV: T:8.13 /0.00 (1000.88) @:0
(pronterface is also sending M105's every 5 seconds...)
The number in the brackets is the raw ADC value (i suspect averaged, as it should only have 0-1023 values. no floats)
Log heating up to 232 like before. and post the results...
Edited 1 time(s). Last edit at 06/20/2020 05:57AM by Dust.
