i'm having some issues running Marlin on a MKS Sbase Board.
I'm using Marlin V2.0.x (and tried Marlin 2.0.5.3) and the related example configuration file for MKS SBase. The firmware can be compiled (VSCode and PlatformIO, environment is set to LPC1768) and is beeing imported (is renamed to firmware.cur). But after a few flashes, the board LEDs stop flashing and the board does not respond to any command.
I think the board is fine, because an older, allready compiled firmware works fine. Unfortunatelly, i don't have the source for this formware to check for differences.
Does anybody have any idea whats wrong? Or maybe someone could check for similar issues with this configuration? As allready said, i tried the example configuration, without any modification.
Thanks in advance.
Best Regards
Matthias
