I recently reflashed my cr10s with marlin 2.0 . I noticed some red lines when it was compiling but is still finished like there was nothing wrong. but when i tried to use g28 the bltouch starts blinking red and doesnt probe. does anybody know what could be wrong
These are the red lines i mentioned
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\sd\SdVolume.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\sd\SdBaseFile.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\sd\Sd2Card.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\tool_change.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\temperature.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\stepper.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\probe.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\planner.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\motion.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\endstops.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\module\configuration_store.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\libs\nozzle.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\ultralcd.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_tune.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_temperature.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_motion.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_media.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_main.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_info.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_filament.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_configuration.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_bed_leveling.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_bed_corners.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu_advanced.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\menu\menu.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\fontutils.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\extui\lib\ftdi_eve_touch_ui\language\language.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\dogm\ultralcd_DOGM.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\dogm\status_screen_DOGM.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\lcd\dogm\lcdprint_u8g.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\temp\M140_M190.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\temp\M104_M109.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\stats\M75-M78.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\stats\M31.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\sd\M32.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\sd\M24_M25.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\sd\M23.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\sd\M1001.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\queue.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\parser.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\motion\M290.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\motion\G4.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\motion\G2_G3.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\motion\G0_G1.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\lcd\M300.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\lcd\M145.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\lcd\M117.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\lcd\M0_M1.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\host\M115.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\host\M114.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\geometry\M206_M428.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\geometry\G92.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\gcode.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\feature\runout\M412.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\feature\pause\M600.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\feature\pause\M125.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M999.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M85.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M80_M81.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M42.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M400.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M226.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\control\M17_M18_M84.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\config\M92.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\config\M221.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\config\M200-M205.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\calibrate\G425.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\calibrate\G28.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\bedlevel\abl\G29.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\bedlevel\M420.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\bedlevel\G42.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\gcode\bedlevel\G26.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\feature\runout.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\feature\pause.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\feature\bedlevel\bedlevel.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\feature\babystep.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\core\utility.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\MarlinCore.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\HAL\AVR\watchdog.cpp
Error while detecting libraries included by C:\Users\keesi\AppData\Local\Temp\arduino_build_727338\sketch\src\HAL\AVR\MarlinSerial.cpp
