Go back to basics
get a control program such as pronterface
connect it to your printer
move Z somewhere safe
home X and Y
move to X0Y0 (in case you home positions are in -ve) eg G1X0Y0
verify X and Y is at 0,0, if it not you need to adjust MANUAL_{X|Y}_HOME_POS
then tell the machine to move X +100 eg G1X100
measure how far it moved, did it move 100mm?
If not you have a issue with your steps/mm or your micro-stepping is not correct for your steps/mm
then tell the machine to move Y +100 eg G1Y100
Once these are correct check your X_BED_SIZE and Y_BED_SIZE values are correct.
And make sure your slicer has the same bed size or any print wont be centered.
Edited 1 time(s). Last edit at 07/09/2020 09:41AM by Dust.
