Hi, I just upgraded from 2.0.5.3 to .4 and somehow don't get the data displayed that I usually had when connecting to the SKR 1.3 board. It used to work. I got a hint that it's about:
"The settings your referring to are only displayed on SERIAL_PORT not SERIAL_PORT_2 and you have SERIAL_PORT connected to a touch screen"
However, I do not understand the comment and it worked before so I'm confused as to why this is an issue with SERIAL_PORT.
See my config here:
M2054_mar.zip
Also, what would be the best way of integrating UBL or ABL on a Delta printer running PrecisionPiezo's latest board?
http://www.marinusdebeer.nl/
