Can marlin z offset like th3d ?
Posted by Burak
July 28, 2020 02:15PM
Hello,
With my old mainboard I was using Th3d software but I changed my mainboard and have to use marlin but with th3d software I could configure zlevel offset realtime (where z level moves when I edit value instantly) but when I start to use marlin it does not work like it . Does marlin have this kind of feature?
Thanks,
Edited 1 time(s). Last edit at 07/28/2020 02:16PM by Burak.
VDX
Re: Can marlin z offset like th3d ?
July 28, 2020 03:32PM
... check the possibilities with the M92 code -- here you can set/define any position, so it can work like an "editable offset" at any time or position ...
Viktor
July 28, 2020 04:41PM
Hello,
No problem is not it is not editable I can edit it but it is not as functonal like th3d it does not do it while printing or it do not change z level in real time when I edit value
VDX
July 28, 2020 06:20PM
... you have to execute a "G0 Z0" move after the M92 redefine to move it to the new offset or "Z0" position ...
Viktor
