[SKR 1.4] WiFi upload: "Please use 8.3 filename only."
August 17, 2020 04:47AM
As the title describes, I have put a lot of work in getting the printer controls to work over WiFi with the TFT35 v3.0 screen from BigTreeTech, everything works, but when I try to upload a gcode file through the web interface I get this error no matter what kind of filename I use. From what I understand this issue was fixed but it stays persistent in my setup.
Does anyone have a solution to this issue?
From what I understand this is an ESP3D issue, but everywhere I look it says this issue has already been fixed. I just can't find the solution.
http://www.marinusdebeer.nl/
VDX
Re: [SKR 1.4] WiFi upload: "Please use 8.3 filename only."
August 17, 2020 06:28AM
... is it the pure filename (e.g. "NNNNNNNN.EEE") or maybe the path or connection-naming added?
Viktor
August 17, 2020 06:49AM
VDX
Using a filename with 8 characters and 3 extension characters does work for the upload. But the main thing is that I haven't found anyone else with this issue so I'm worried that this error is only hitting a few people. I'm starting to think maybe it's not the TFT35 but it's maybe the ESP3D.bin file I used, it may not be the latest and maybe I should flash the more modern .bin file with a FTDI programmer?
I'm on a macbook so I cannot use the windows FTDI flasher from BigTreeTech sadly confused smiley
Edited 1 time(s). Last edit at 08/17/2020 06:50AM by Ohmarinus.
August 20, 2020 01:18PM
Moved to Marlin since the ESP3D creator said it's a Marlin limitation. It's quite mindboggling how nobody else seems to have this issue. Or simply nobody uses the SKR 1.4 with screen and upload?
Anyway, my issue persists and flashing new firmware on the ESP-01S didn't help. If anyone knows how to approach this issue I would be grateful!
Some more info:
[github.com]
Can it be that '#define LONG_FILENAME_HOST_SUPPORT' has anything to do with it?
Edited 1 time(s). Last edit at 08/20/2020 01:31PM by Ohmarinus.
September 01, 2020 09:30AM
I tried everything. ESP3D supports long filenames and it's a shortcoming of Marlin. Just bumping this post in hopes of someone knowing the solution. Meanwhile I'll try Reddit smiling smiley
February 01, 2021 05:05PM
I have that same problem. does anyone solve this problem.
February 04, 2021 05:24PM
Shot in the dark. Could it be a function of vfat?
[en.wikipedia.org]
Try formatting the card as fat32 or some such. I use octoprint so this is a guess.
February 05, 2021 04:27AM
FYI I have an SKR1.4 as well running marlin 2.0. I started using Octoprint and also noticed that all files that are still located on the SD card inside the printer have a 8.3 filename.
