Upgrading from Marlin 1.1.9 to Marlin 2.0.x causes problems with extruder
Posted by Abi91
August 29, 2020 12:48PM
I've been trying to upgrade my Marlin firmware from 1.1.9 to 2.0.x. Unfortunately it's causing me issues although I configured 2.0.x with the same settings as 1.1.9.
Here is how it looks like with 1.1.9: Youtube Link
Here is how it looks like with 2.0.x:Youtube Link
I'm using a Makerfarm Prusa i3v with a Ramps 1.4 Board. I use Watterott TMC2208 drivers in standalone mode for all axis. From what I can gather it happens at places where a lot of retractions happen in succession but I have no clue what the causes this.
What I already tried:
-Disable Linear Advance and/or S-Curve Acceleration
-Set MINIMUM_STEPPER_PULSE to 1
-Enable SQUARE_WAVE_STEPPING
-Decrease acceleration from 1000 mm/s^2 to 500 mm/s^2
-Enable Classic Jerk settings
-Reset EEPROM settings
-Checked and compared the EEPROM settings with M503
Edited 1 time(s). Last edit at 08/29/2020 01:11PM by Abi91.
Re: Upgrading from Marlin 1.1.9 to Marlin 2.0.x causes problems with extruder
September 28, 2020 05:06AM
For those that might have the same problem, here is what I did:
-Apparently this issue was caused by Simplify3d, so I changed to Cura and that fixed the issue
-Just to be sure I change my drivers from TMC2208 to TMC2209 (since I wanted to use Linear Advance, but apparently the TMC2208 might cause issues with it)
