Hello everyone, everything good?
I use Creality Ender 3 PRO. I bought the MKS Robin E3 board and managed to install the Marlin firmware normally. However I tried to install the BLTouch sensor together with the firmware and I am not getting success. I found Configuration.h and Configuration_adv.h for the printer. But even so, the BLTouch sensor recognizes, the extraction and retraction commands work, but the PB1 port in Bilinear calibration, at the beginning of printing it does not level with the table and I end up needing to use an Offset Z for each type of height on the table, as if I had manually calibrated it. I followed the tutorial posted by MKS and I couldn't get the sensor to work fully. Follow the wiki:
MKS-Robin-E3-E3D - 3D_TOUCH
Another strange thing that my sensor only passed the expansion and retraction test when I inverted the pins S G 5V by 5V G S; and the same thing for PB1; that from S G - I had to change to G S.
Is this wiki really up to date? Does anyone have this card model and could help me in this configuration?
Edited 1 time(s). Last edit at 09/16/2020 12:59PM by tassiolucas.
