Gadget3D Printer updating to latest Marlin November 02, 2020 04:51AM |
Re: Gadget3D Printer updating to latest Marlin November 02, 2020 07:04AM |
Admin Registered: 15 years ago Posts: 7,333 |
Re: Gadget3D Printer updating to latest Marlin November 02, 2020 08:40AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Gadget3D Printer updating to latest Marlin November 02, 2020 08:51AM |
Re: Gadget3D Printer updating to latest Marlin November 02, 2020 11:15AM |
ianch
Hi
From the M503 command, which of values marry up to the values in the configuration.h file.
Yes, I've got the Gadget3D display as well
Do you have configuration.h and configuration_adv.h files that you can share, please?
Re: Gadget3D Printer updating to latest Marlin November 03, 2020 01:27PM |
Re: Gadget3D Printer updating to latest Marlin November 03, 2020 04:50PM |
ianch
Argh!!!
I'm confused....
I'm looking at the page GADGET3D Shield
On that page it says to edit the file pins_RAMPS_14.h but on the latest version of Marlin 2 there is no such file.
So the question is where should I put all those #defines for the Gadget3D shield pins?
Re: Gadget3D Printer updating to latest Marlin November 03, 2020 08:43PM |
Roberts_Clif
GADGETS3D
Technical specifications:
Build Volume (L | W | H - mm) 200 x 200 x 200
Precise laser cut acrylic frame
Wade style Extruder
G3D Hot-End for 1.75mm/3mm PLA/ABS (pre-assembled)
Nozzle diameter 0.4mm/0.5mm
Material: 1.75mm/3mm PLA, ABS, Nylon, Laybrick, Laywood
High power RAMPS 1.4 electronics (pre-configured)
G3D Stepper Motor drivers
High torque NEMA 17 Steppers Motors
G3D LCD display with G3D Shield including SD card reader and SD Card for standalone operation
4-point platform leveling
Removable acrylic sheet for good adhesion and easy part removing
Recommended software: RepetierHost & Slic3r
Assembly manual
Marlin firmware (pre-configured)
After a little research I found this information
Marlin
Configuration.H
#define MOTHERBOARD 34 // Sets the Motherboard as Ramps 1.3/1.4 with two extruders = #define MOTHERBOARD BOARD_RAMPS_14_EFB
#define TEMP_SENSOR_0 1 // This defines the first temperature sensor as a 100k thermistor.
#define G3D_PANEL // Un-comment this line to enable the Gadgets3d LCD and SD panel.
Re: Gadget3D Printer updating to latest Marlin November 04, 2020 07:50AM |
Re: Gadget3D Printer updating to latest Marlin November 09, 2020 09:39AM |
#ifndef MOTHERBOARD
#endif
#define TEMP_SENSOR_BED 0 // Change to 1 if you've added a hot bed
#if ENABLED(PIDTEMP)
#if ENABLED(PID_PARAMS_PER_HOTEND)
#else
// G3D HotEnd v1.2 - Taken from my V1.0 Marlin supplied with the G3D
#define DEFAULT_Kp 31.43
#define DEFAULT_Ki 2.34
#define DEFAULT_Kd 105.57
#endif
#endif
// Mechanical endstop
#define X_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe.
// Changed from default because the Z axis was moving at double the distance.
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 2000, 746 }
// Changed to match the V1.0 Marlin supplied with the G3D
#define DEFAULT_MAX_FEEDRATE { 400, 400, 3, 20 }
#define DEFAULT_MAX_ACCELERATION { 7000, 7000, 25, 10000 }
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 2000 // X, Y, Z acceleration for travel (non printing) moves
#define CLASSIC_JERK // uncomment
#if ENABLED(CLASSIC_JERK)
#define DEFAULT_XJERK 15.0
#define DEFAULT_YJERK 0.3
#define DEFAULT_ZJERK 3.0
#endif
#define INVERT_X_DIR true
#define INVERT_Y_DIR false
#define INVERT_Z_DIR true
// The size of the print bed on Gadget3D
#define X_BED_SIZE 180
#define Y_BED_SIZE 180
#define Z_MAX_POS 170
* EEPROM
#define EEPROM_SETTINGS // Persistent storage with M500 and M501 - Uncomment this line
#define PREHEAT_1_FAN_SPEED 255
#define PREHEAT_2_FAN_SPEED 255
#define SDSUPPORT
#define REVERSE_ENCODER_DIRECTION
#define REVERSE_MENU_DIRECTION
//#define G3D_PANEL
#define G3D_PANEL
// I found the below settings from [reprap.org]
// But they don't seem to be needed
// So left commented out
//#define BEEPER 33 // Beeper and is Connected into GADGETS3D shield MEGA_18BEEPER
//#define LCD_PINS_RS 16 // LCD control and is connected into GADGETS3D shield LCDRS
//#define LCD_PINS_ENABLE 17 // LCD enable pin and is connected into GADGETS3D shield LCDE
//#define LCD_PINS_D4 23 // LCD signal pin, connected to Gadgets3D shield LCD4
//#define LCD_PINS_D5 25 // LCD signal pin, connected to Gadgets3D shield LCD5
//#define LCD_PINS_D6 27 // LCD signal pin, connected to Gadgets3D shield LCD6
//#define LCD_PINS_D7 29 // LCD signal pin, connected to Gadgets3D shield LCD7
//#define BTN_EN1 37 // Encoder left direction, connected to Gadgets3D shield S_E1
//#define BTN_EN2 35 // Encoder right direction, connected to Gadgets3D shield S_E2
//#define BTN_ENC 31 // Encoder Click, connected to Gadgets3D shield S_EC
Re: Gadget3D Printer updating to latest Marlin November 09, 2020 11:26AM |
