Hi everyone,
I have a Geeetech i3 PRO W (actual FW 1.0.0.5 stock) and I'm trying to update the FW with the Marlin 2.0.7.2 version by doing this:
- Downloaded the FW Marlin 2.0.7.2 from the site
- Downloaded configuration.h and configuration_sdv.h from sample configurations
- Replaced configuration.h and configuration_sdv.h
In ArduinoIDE it crashes at 1/3 of the verification process
In PlatformIO the following error comes out:
Processing mega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
In file included from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfig.h:34:0,
from buildroot/share/PlatformIO/scripts/common-dependencies.h:31:
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/../pins/pins.h:767:6: error: #error "Unknown MOTHERBOARD value set in Configuration.h"
CalledProcessError: Command '"C:\Users\dorrico\.platformio\packages\toolchain-atmelavr\bin\avr-g++.exe" -D__MARLIN_FIRMWARE__ -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\Users\dorrico\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 168:
env.SConscript(item, exports="env")
File "C:\Users\dorrico\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
return _SConscript(self.fs, *files, **subst_kw)
File "C:\Users\dorrico\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
File "C:\Users\dorrico\Desktop\Stampa 3d\Marlin-bugfix-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 287:
apply_features_config()
File "C:\Users\dorrico\Desktop\Stampa 3d\Marlin-bugfix-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 118:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\dorrico\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
return self.method(*nargs, **kwargs)
File "C:\Users\dorrico\Desktop\Stampa 3d\Marlin-bugfix-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 263:
load_marlin_features()
File "C:\Users\dorrico\Desktop\Stampa 3d\Marlin-bugfix-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 251:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\dorrico\.platformio\python3\lib\subprocess.py", line 411:
**kwargs).stdout
File "C:\Users\dorrico\.platformio\python3\lib\subprocess.py", line 512:
output=stdout, stderr=stderr)
==================================================================== [FAILED] Took 1.29 seconds ====================================================================
Environment Status Duration
mega2560 FAILED 00:00:01.291
=============================================================== 1 failed, 0 succeeded in 00:00:01.291 ===============================================================
Sono un inesperto sognatore/smanettone con una Geeetech i3 PRO W e tanta voglia di imparare
