Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe July 24, 2021 05:41PM |
// RAMPS 1.4 DIO 4 on the servos connector #ifndef FIL_RUNOUT_PIN #define FIL_RUNOUT_PIN 11 #define FIL_RUNOUT2_PIN 40 // was pin 6 before, but I want to use the pwm-pin for the part cooling fan now
/** * Part-Cooling Fan Multiplexer * * This feature allows you to digitally multiplex the fan output. * The multiplexer is automatically switched at tool-change. * Set FANMUX[012]_PINs below for up to 2, 4, or 8 multiplexed fans. */ #define FANMUX0_PIN 6 #define FANMUX1_PIN -1 #define FANMUX2_PIN -1
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe July 25, 2021 07:49AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe July 25, 2021 08:01AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe July 25, 2021 08:11AM |
14:08:25.727 > start 14:08:25.728 > Marlin bugfix-2.0.x 14:08:25.728 > 14:08:25.728 > echo: Last Updated: 2020-12-30 | Author: CySign 14:08:25.730 > echo:Compiled: Jul 25 2021 14:08:25.732 > echo: Free Memory: 3288 PlannerBufferBytes: 1200 M106 14:08:31.182 > echoD card ok 14:08:31.355 > echo:Unknown command: "M106" 14:08:31.355 > ok M106 S150 14:08:46.236 > echo:Unknown command: "M106 S150" 14:08:46.238 > ok
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe July 25, 2021 09:39AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 16, 2021 12:38PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 17, 2021 07:19PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 18, 2021 12:37PM |
Trying 2mm right now. Just compiled and uploaded Marlin using the new valueQuote
yet-another-average-joe
change DEFAULT_LEVELING_FADE_HEIGHT in Configuration.h for a smaller value (default = 10mm).
Good question, next one.Quote
[EDIT] do you print infill before walls, and/or outer wall before inner wall ?
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 18, 2021 02:58PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 18, 2021 03:27PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 18, 2021 09:53PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 19, 2021 01:20PM |
I'll try this right nowQuote
If your model is 60.5mm and you print 59mm, you have to increase Z-steps by 2.5%, or multiply by 1.0254 : if 400 steps/mm, you could test with 410 ; it has nothing to do with Z-offset.
Looks like this is the default setting for Cura.Quote
printing inner wall before outer wall is probably better
I'm going to print a z-axis calibration part...but I didn't find a good one to calibrate z-axis. Any suggestions?Quote
On your website, we can see you have some machine tools. If you have machine tools, you also have at least one DTI. You could also verify that a 10mm move gives a 10mm reading, and test at different heights, using a 123 block on the bed : at bed height, at 25mm, 50mm and 75mm
If the screws are my problem, I'll change them. But first I have to check this.Quote
Cheap chinese leadscews accuracy and linearity is... cheap !
Just wanted to start building the machine...and a welded frame sounded better than one based on wood (at least as far as I can't cnc mill it). So I just started.Quote
Your printer design is interesting (Z motors on the X axis and isostatic leadscrews arrangements, welded frame, built like a tank). Welding perfectly flat and square is extremely difficult. Does the X axis smoothly moves up and down ? (perfect parallelism, no skew ?) Never seen this design on a 3D printer, it's more common on CNC routers and plasma cutters AFAIK.
That's my Plan B...but as I would like to print many edrum-pads...that's the worst case. I'd better align my machine properly before printing many edrum padsQuote
You can heat the nut before inserting it. And as long as all the parts are the same height, it probably does not really matter if the drum is 60.5 or 59mm. I'd print everything, make the drum pad, and fine adjust the printer later !!! Or you'll have to throw this print away...
It just looks like this on the image. What seems to be curved, is curved. It's the outer wall - which is a radius somewhere close to 6". The bottom looks nearly perfectly flat (except the two parts where my BuildTak is damaged...I'm going to replace it as soon as I get decent printing results).Quote
It seems the bottom of the print (picture 82.jpg) is not flat. Looks like it's warped and there was a problem with bed adhesion. Just below the hexagon. This could explain the problem with hexagon and the nut not fitting well.
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 19, 2021 03:51PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 19, 2021 07:36PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 20, 2021 12:54PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 20, 2021 07:57PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe August 21, 2021 09:55AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe September 18, 2021 03:00PM |
