LCD not working with SKR 1.4V turbo
Posted by Sagar
December 04, 2020 12:54AM
Hi ,
We are connecting LCD2004 to SRK-V1.4, but we see LCD is not displaying any data.
On probing we found the Enable and RS pins on LCD section are not proper
RS signal is always high and low and EN signal is low
Can you help on this regard what could be pattern of these two signals so that we can compare to working module
Re: LCD not working with SKR 1.4V turbo
December 04, 2020 02:07AM
Many 20x4 lcd's have their plugs flipped 180 degrees. They often come with a ramps which isn't a issue as they also supply the lcd interface board to suit. But on a SKR 14 It is just one way so you have to get a lcd that maches.
Check your controller 5v is on the lcd 5v pin
The LCD should light up
Edited 2 time(s). Last edit at 12/04/2020 02:13AM by Dust.
December 05, 2020 09:48AM
I agree with Dust that these LCD problems are often down to plug orientation.
With some care you can remove the plug plastic socket on the mother board and rotate it 180 degrees then press it back into place.
January 04, 2021 03:06PM
Hello,
My BTT TFT35 was working fine with SKR 1.4V Turbo using buildfix 2.0x from May, 2020. However, I just tried to update to the latest buildfix repository, and my LCD just continues to "reboot". I think it has something to do with changes made to the pins_BTT_SKR_V1_4 file, but I can't seem to figure it out.
January 04, 2021 04:02PM
@garyr14 you would have better luck getting support if your didn't attach your issues to unrelated old issues of others.
Original post was about LCD2004 lcd , nothing like a BTT TFT35 !
