Homing Issue in SKR 1.4V TURBO
Posted by Sagar
December 05, 2020 08:20AM
Hi sir
I am facing a problem with auto homing. when ever I do auto home the x,y,z move 1 cm and stops that to in opposite direction
please help
Thanks in advance
Re: Homing Issue in SKR 1.4V TURBO
December 05, 2020 04:40PM
When this happens it say the the end-stop is already activated.
Use M119 to test the End Stop Switches.
December 06, 2020 05:52AM
This can also happen when you have the stepper direction the wrong way round in firmware
The firmware wont allow complete movement till all axis are homed
so you can change the wiring on the stepper motor(s) to reverse the direction or alter the direction in firmware
Good luck
Edited 1 time(s). Last edit at 12/06/2020 05:52AM by bigfilsing.
December 06, 2020 06:07AM
With the skr1.4 there is also the conflict between endstops and tmc stepper drivers
If you have endstops you need to remove the diag pins from the tmc stepper drivers or they interfere with each other.
