Marlin 2.0.5.3 to 2.0.7.2 challenges
Posted by jdebuhr
December 21, 2020 09:35PM
Hello,
I am wanting to go from 2.0.5.3 to 2.0.7.2, I can compile the 2.0.5.3 in Arduino IDE but cannot do it with 2.0.7.2.
I remember someone saying PlatformIO is the better alternative.. so I have gone through a bunch fo stuff I go to the Auto Build Marlin. I have my Config files in the 2.0.7.2 directory but when I try to run I get this:
PS C:\RepRap\Marlin-2.0.x> platformio run -e rambo
platformio : The term 'platformio' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:1
+ platformio run -e rambo
+ CategoryInfo : ObjectNotFound: (platformioconfused smileytring) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\RepRap\Marlin-2.0.x> echo "done" >C:\Users\jeffd\AppData\Local\Temp\ipc
Now I think I added the right info to the system path to allowing it to run. This is the Path I added
C:\Users\jeffd\.platformio\penv\Scripts;
but I still get the error..
Please Help
Re: Marlin 2.0.5.3 to 2.0.7.2 challenges
December 21, 2020 09:44PM
Made progress.. Helps to reboot the PC.. however I still get errors
Processing rambo (platform: atmelavr; board: reprap_rambo; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing platformio/tool-scons @ ~4.40001.0
Tool Manager: tool-scons @ 4.40001.0 has been installed!
Tool Manager: Removing tool-scons @ 3.30101.0
Tool Manager: tool-scons @ 3.30101.0 has been removed!
*** No platform named 'win32'
File "C:\users\jeffd\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 91, in
================================================================================================== [FAILED] Took 8.17 seconds ==================================================================================================
Environment Status Duration
rambo FAILED 00:00:08.171
December 21, 2020 10:25PM
PlatformIO is the best way to go on windows.
But something is quite broken with your platformio install
December 21, 2020 10:49PM
Dust
Got further.. Ran it again and I used the Config from 2.0.5.3 which apparently is not the same in the 2.0.7.2
SO, I need to do a compare and set up the 2.0.7.2 with my 2.0.5.3 changes and try again..
But I am making progress. I have the time as I am waiting for hardware to finish swapping away from the acrylic frame
December 21, 2020 10:52PM
you definitely cannot use older configs on newer marlin.. this include platformio.ini, Configuration.h and Configuration_adv.h files.
December 21, 2020 11:02PM
Yeah so I assume I have to hand edit them.. That will be tomorrows task to edit and get the 2.0.7.2 set up (Meaning Configuration.h and Configuration_adv.h. I assume manually editing is ok with Platform IO? Or do you do everything in PlatformIO.ini ?
December 22, 2020 05:57AM
grab a default config from 2.0.5.3 and do a diff with your config, then you know what you modified and can apply just that to the new config. As a first pass anyways.
December 22, 2020 09:54AM
I found WinMerge allows for a much faster duplication or editing of the configuration files in Marlin firmware.
December 24, 2020 08:45PM
Got it.. I compared the Configuration and Configuration_adv in Notepad++ I changed everything I have currently set from 2.0.5.3
Now It complies, and builds to my Rambo 1.3 I am able to move my Z and X. I am still in process of rebuilding my Acrylic printer on an Aluminum frame and fixing other small issues.
I do have a question on Marlin firmware. I have another printer with Prusa MK2 Firmware. there is a Live Z adjust feature, is there something like this in Marlin? Also the bed level code I am using is where it checks 9 points. is there a better or another one bed leveling I should try? I am trying to determine the final firmware for this printer that will use.
December 24, 2020 09:05PM
Live Z is called babystepping in Marlin
there are 5 different bed leveling systems.
which one is best is up to you.
personally they are all excuses not to actually level your bed for real
December 25, 2020 11:11AM
Dust
Yes, But what kind of process do you go through to manually level your bed? Do you do it every time you print?
December 25, 2020 11:46AM
I enable the Babystepping in marlin, it could be considered a crutch I guess if you use it that way. This is mainly for the Nozzle height.
I level the bed manually, though some times do not get it perfect so the baybstepping allows me to quickly adjust to a good height during printing the skirt.
Keeping track of how far I adjusted using babystepping, then I can use this to turn my thumb screw adjustable proximity sensor slide mount height to correct.
If you have your thumb screw adjuster color coded in quarters or even numbered 0 - 9 after a few time making the adjustment you can simple turn the Thumb Screw to that setting,
Edited 1 time(s). Last edit at 12/25/2020 11:49AM by Roberts_Clif.
January 04, 2021 04:34PM
Quick update..
Got VSCode working.. that is a nice way to upload Marlin.
I will say, it is amazing how well a unit can work with a solid frame (Aluminum vs Acrylic) and a bit of time to dial in everything. my PLA Prints I have tested look great!!
Next to dial in PETG
