Remaining time compile error
Posted by Gertfriend
January 11, 2021 08:14AM
Hello,
does anybody know what this errors mean:
sketch\src\lcd\HD44780\marlinui_HD44780.cpp: In function 'uint8_t draw_elapsed_or_remaining_time(uint8_t, bool)':
sketch\src\lcd\HD44780\marlinui_HD44780.cpp:711:35: error: 'class MarlinUI' has no member named 'get_remaining_time'
duration_t remaining = ui.get_remaining_time();
exit status 1
Fehler beim Kompilieren für das Board Arduino Mega or Mega 2560.
This error comes out when i enable #define USE_M73_REMAINING_TIME
I tried with Arduino IDE and Visual Studio.
The firmware used is the marlin-bugfix-2.0.X.
Thanks for any answer.
Re: Remaining time compile error
January 11, 2021 05:14PM
You have found a bug.
It should warn you when you enable USE_M73_REMAINING_TIME you must have also have LCD_SET_PROGRESS_MANUALLY to actually enable M73
Edited 2 time(s). Last edit at 01/11/2021 05:20PM by Dust.
January 11, 2021 06:17PM
I have created a PR to fix this
[github.com]
January 12, 2021 05:38AM
Thank you very much. Now its working.
