ENDER 3 V2 SKR 1.4 TURBO compilation issues January 15, 2021 10:02AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 15, 2021 08:33PM |
Admin Registered: 13 years ago Posts: 7,002 |
#if ENABLED(DWIN_CREALITY_LCD) #define SERIAL_CATCHALL 0 #ifndef LCD_SERIAL_PORT #define LCD_SERIAL_PORT 3
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 15, 2021 10:18PM |
Marlin/src/lcd/dwin/e3v2/dwin.cpp:500:71: warning: use of 'auto' in parameter declaration only available with '-fconcepts' 500 | inline bool Apply_Encoder(const ENCODER_DiffState &encoder_diffState, auto &valref) {
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 01:58AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 04:19AM |
* Ender 3 V2 display SKR 1.4 TURBO EXP1 SKR 1.4 TURBO WIFI * _____ _____ _____ * 5V | 1 2 | GND 5V | 1 2 | GND 4.28 | 1 2 | 3.3V * (BTN_E1) A | 3 4 | B (BTN_E2) 1.23 | 3 4 | 1.22 NC | 3 4 | NC * BEEP | 5 6 ENT (BTN_ENC) 1.21 | 5 6 1.20 NC | 5 6 | NC * TX | 7 8 | RX 1.19 | 7 8 | 1.18 GND | 7 8 | 4.29 * NC | 9 10| NC 0.28 | 9 10| 1.30 ----- * ----- ----- * EXP1
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 04:50AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 07:41AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 08:06AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 08:43AM |
#if ENABLED(DWIN_CREALITY_LCD) #define SERIAL_CATCHALL 0 #ifndef LCD_SERIAL_PORT #define LCD_SERIAL_PORT 3 // Creality 4.x board #define LPC_PINCFG_UART3_P4_28 // RX/TX from WIFI port on SKR 1.4 TURBO #endif #endif
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues January 16, 2021 05:31PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 26, 2021 11:30PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 26, 2021 11:33PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 27, 2021 02:14AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 28, 2021 07:19PM |
Chwal
To answer your first question, have a look at the table above with serial 3. The def uart 3 P4 is activating both 28 and 29.
Maybe recheck you routing ?
I’m not home but I’ll check when I come back in 2 weeks and let you know if I find more advice.
Wishing you a nice day !
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 28, 2021 07:42PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues April 29, 2021 12:33AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues May 24, 2021 03:12PM |
Dust
The warnings are a concern.
The variable is a char ie 0-255 but the case is looking for negative numbers as well.
The fix is in dwin.h
I have created a PR to fix this [github.com]
Only 1 warning remains,
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues May 24, 2021 04:25PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 11, 2021 06:45PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 14, 2021 08:13PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 14, 2021 10:15PM |
#if HAS_DGUS_LCD #define LCD_SERIAL_PORT 3
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 15, 2021 01:16AM |
#if ENABLED(DWIN_CREALITY_LCD) #ifndef BEEPER_PIN #define BEEPER_PIN EXP1_10_PIN #undef SPEAKER #endif #define BTN_EN1 EXP1_03_PIN #define BTN_EN2 EXP1_04_PIN #define BTN_ENC EXP1_06_PIN #endif
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 15, 2021 05:21AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 18, 2021 02:24PM |
Dust
"why do I have to change the lcd serial port at
#if HAS_DGUS_LCD?
I use creality dwin"
read the comment above HAS_DGUS_LCD in Configuration_adv.h
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 22, 2021 03:30PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 22, 2021 09:36PM |
* Ender 3 V2 display SKR E3 Turbo EXP1 * _____ _____ * 5V | 1 2 | GND 5V | 1 2 | GND * (BTN_E1) A | 3 4 | B (BTN_E2) BTN_EN1 0.18 | 3 4 | 0.17 BTN_EN2 * BEEP | 5 6 ENT (BTN_ENC) TX 0.15 | 5 6 0.20 BTN_ENC * TX | 7 8 | RX RST | 7 8 | 0.19 * NC | 9 10| NC RX 0.16 | 9 10| 2.08 BEEPER_PIN * ----- ----- * EXP1
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues June 24, 2021 12:14PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues October 12, 2021 08:29AM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues November 28, 2021 12:10PM |
Re: ENDER 3 V2 SKR 1.4 TURBO compilation issues November 28, 2021 01:57PM |
womit
Hi Guys
Any chance of helping me get a e3v2 screen working with a skr 2?
I assume i can use the tft port for rx/tx im just not sure how to set up the port.
Thanks' for any help in advance Dave
