Quick Return to Info Screen?
February 23, 2021 09:10PM
So, you're buried deep in the Marlin sub-menus and want to get back to the top-level Info Screen.
Scroll-up, click on the top entry to go back one menu
. . . etc
Yay! Made it back to the Info Screen!
Is there a quick return to the Info Screen that I haven't found yet?
I haven't found anything in the docs
Thanks!
Edited 1 time(s). Last edit at 02/23/2021 09:10PM by DaHai8.
Re: Quick Return to Info Screen?
February 23, 2021 09:30PM
If you define LCD_TIMEOUT_TO_STATUS the default value 15000 then you just wait 15 seconds and it returns to the status screen
It can also depend on your type of 'screen'
Edited 2 time(s). Last edit at 02/23/2021 09:34PM by Dust.
February 23, 2021 09:43PM
The screen I'm currently using is the LCD12864 / REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER, ie: the ones plugged into EXP1 and EXP2 (and even the one used by MKS (MKS_MIN_12864 / MKS_LCD12864) and CR10_STOCKDISPLAY, etc)
March 01, 2021 09:24PM
// BACK menu items keep the highlight at the top
#define TURBO_BACK_MENU_ITEM
Config adv
March 02, 2021 05:36AM
jaded
Config adv
I saw that. It just allows for easy return to the previous menu, not a jump all the way back to the Info Screen
March 02, 2021 08:17AM
I genuinely hope your feature request can be completed.
I rarely use the lcd screen for anything which is why I am still using my trusty reprap full graphics. At the minimum I use the lcd to test homing when flashing firmware, test movements (and speeds/velocity/jerks etc.), reset eeprom, set nozzle offset, set TMC settings, and set TMC currents. All during the testing phase and offline. Once the testing is done I just leave it on the main info screen and control the printer from repetier server.
