I'm building a AM8 frame with a SKR1.4 turbo board with Marlin "2.0.5.4" and TMC2130 silient stepper driver and a 230V heated bed.
So far so good. All the steppers work, the bed heats (135°C max) the extruder heats. BL-Touch works.
The homing switches work too, except if the x-axis is all the way to the right (switch is left) and the y-axis is all the way forward (switch is in the back)
When I start the homing and the x and y axis are aprox. in the middle of their respective travel ranges - the homing works.
When they are the maximum distance away from the switches, the homing procedure stops message "homing failed printer halted..." is displayed.
Is there a config setting where I can tell marlin how far it can move during homing?
Thanks in advance.
Edited 1 time(s). Last edit at 02/28/2021 12:05PM by zero_mc_null.
