M7 M8 M9 "unrecognized command" even with #define COOLANT_CONTROL
Posted by rc3105
March 04, 2021 11:51PM
Cans someone sanity check me please?
I'm trying to use M7 / M8 / M9 for an ink pump, but all I get is
echo:Unknown command: "M8" (same for M7, or M9)
This is Marlin 020007 and I have these defined.
#if ENABLED(COOLANT_CONTROL)
#define COOLANT_MIST A5 // Enable if mist coolant is present
#define COOLANT_FLOOD A4
What am I missing???
thx
Re: M7 M8 M9 "unrecognized command" even with #define COOLANT_CONTROL
March 05, 2021 02:04AM
        #if ENABLED(COOLANT_MIST)
          case 7: M7(); break;                                    // M7: Mist coolant ON
        #endif
        #if ENABLED(COOLANT_FLOOD)
          case 8: M8(); break;                                    // M8: Flood coolant ON
        #endif
        case 9: M9(); break;                                      // M9: Coolant OFF
      #endif
So you need COOLANT_CONTROL for M9 and you need COOLANT_MIST for M7 and COOLANT_FLOOD for M8
you should not have things after the define name, eg
  #define COOLANT_MIST                // Enable if mist coolant is present
  #define COOLANT_FLOOD               // Enable if flood coolant is present
the pins are defined with COOLANT_MIST_PIN and COOLANT_FLOOD_PIN not in the above defines.
Cant explane M9 though...
Edited 1 time(s). Last edit at 03/05/2021 02:13AM by Dust.
March 05, 2021 02:25AM
duh@me, thx
#define COOLANT_MIST_PIN 22
#define COOLANT_FLOOD_PIN 44
workin fine...
