I have Marlin 2.0.7.2 installed on an Anycubic Predator delta. I have the "pause for deploy/stow" function turned off in configuration.h as I am using a permanently mounted piezo sensor under the bed. When I start an M48 probe repeatability test, a delta auto-calibration, or bed leveling, the unit homes fine. Then it descends at a good speed to where it used to stop and ask for a probe deployment. It doesn't do that anymore (good), but it does slow down at that point, 300 millimeters or so above the bed, and proceed down at the probing speed (very slow).
Is there a way to make the machine go to within a few millimeters of the bed, and THEN slow down to probe? I'm sure I'm missing something in the configuration files, but darned if I can find it!
