TMC2209 Error with Tevo Tornado V2 using latest Marlin firmware
Posted by devguy
March 27, 2021 11:05PM
Hi all, so several weeks back I successfully built Marlin firmware when I installed MakerbaseTMC 2209 v2 drivers on my Tevo Tornado and everything was working fine.
Well a few days I decided to use the latest Firmware, now I am seeing errors.
Using gcode M122, I see:
Recv: Testing X connection... Error: All LOW
Recv: Testing Y connection... Error: All LOW
Recv: Testing Z connection... Error: All LOW
Recv: Testing E connection... Error: All LOW
I haven't changed anything on my printer, I've checked my file diff several times with my Configuration files and I don't see anything off. I've re-watched the YouTube setup video by Makerbase to make sure I didn't fat finger anything.
Has anyone reported the same? Can anyone help.
Here is my configuration file: [github.com]
The motherboard I am using is MSK Gen L V1.0
TMC2209 Driver v2.0 made by Makerbase
Re: TMC2209 Error with Tevo Tornado V2 using latest Marlin firmware
March 27, 2021 11:22PM
#define MOTHERBOARD BOARD_MKS_BASE
// #define MOTHERBOARD BOARD_MKS_GEN_L
Why is BOARD_MKS_GEN_L commented out?
March 27, 2021 11:24PM
Where is the original configuration file? for comparison?
March 27, 2021 11:57PM
Edited 1 time(s). Last edit at 03/28/2021 06:58PM by pacos526.
March 27, 2021 11:58PM
Edited 1 time(s). Last edit at 03/28/2021 06:59PM by pacos526.
March 28, 2021 12:00AM
dammit, it put me in a different topic lol, sorry about that
March 28, 2021 12:31AM
The original is BOARD_MKS_BASE
I tired the other but didn't correct the error so I left it commented out.
March 28, 2021 12:33AM
The original Tevo Tornado firmware is here: [github.com]
the latest Marlin firmware is here: [github.com]
Edited 1 time(s). Last edit at 03/28/2021 12:35AM by devguy.
March 28, 2021 12:42AM
@pacos526 the ender pro 3 is not Tevo Tornado, nor do they use the same motherboard, if you're going to hi-jack this thread it's going to cause more confusion.
March 28, 2021 01:44AM
So I think I made this mistake in the past and don't recall what I did to fix it, but MKS GEN-L V1.0 does not support UART, I need to disable this in the firmware, how do I do this?
The markerbase videos are horrible which doesn't help my situation.
March 28, 2021 02:03AM
I think my solution is to comment out the drivers, otherwise I believe this put the firmware into UART mode, which is not supported by my motherboard and thus is reporting an error.
// #define X_DRIVER_TYPE TMC2209
// #define Y_DRIVER_TYPE TMC2209
// #define Z_DRIVER_TYPE TMC2209
// #define E0_DRIVER_TYPE TMC2209
If someone knows better please advice.
March 28, 2021 03:37AM
it doesn't support it as plug in play.
but you can wire it to support uart, with some soldering and connecting uart pins to aux2
March 28, 2021 12:37PM
sorry about that, how do I delete my comments? I'm new to this forum
March 28, 2021 03:35PM
pacos526
No worries, I suggest you do a search first in the forum for answers and only create a post asking for help if you don't find a solution.
Make sure to put all the info, like if you just purchased the 3d printer and try to build a new firmware for it,
or did you purchase a new board (make, model, version) same for the TMC2209 driver chips (make, model, version).
Where you got the original configuration files or what you changed yourself.
Here is an example search you can try ("TMC2209 connection error"): [reprap.org]
Maybe look through these results see if anything helps.
Edited 2 time(s). Last edit at 03/28/2021 03:37PM by devguy.
