Wrong temp reading on heater sensor
Posted by PickyBiker
April 01, 2021 03:05PM
I have a DIY printer with Marlin 2.0, an Arduino MEGA 2560 and a RAMPS 1.4. It has two of the same temperature sensors in it that read differently by about 11 degrees. If the bed reads about 20 degrees (which is the actual room temp), the extruder reads about 9 degrees. I tried a 3rd sensor in the heater with the same result.
Is there a way to adjust the temp reading up by 11 degrees in the firmware?
Edited 3 time(s). Last edit at 04/01/2021 03:07PM by PickyBiker.
Re: Wrong temp reading on heater sensor
April 02, 2021 03:22PM
Have you tried connecting the bed heater sensor to the hot end sensor input and see if that also reads 20C? Perhaps they are not the same sensor type.
April 04, 2021 10:42AM
MMcLure you are correct. Although they look the same, they are not. I found a pair that read correctly on both.
Thank you.
