Hi, This week I upgraded from my RAMPS 1.4 to a BTT SKR 1.4 Turbo and loaded Marlin 2.0.8
I had bed levelling work with the initial testing in Pronterface but now it refuses to work right.
I found in my Configuration.h file this and I tried enabling both the restore and enable:
* Normally G28 leaves leveling disabled on completion. Enable one of
* these options to restore the prior leveling state or to always enable
* leveling immediately after G28.
#define RESTORE_LEVELING_AFTER_G28
//#define ENABLE_LEVELING_AFTER_G28
This did not fix the issue and the M420 S1 (between G28 and G29) also did not fix it BUT I seem to have found the root cause of my leveling not working fine. I let it do multiple probing per point (2x). The first in the center is fast then slow. Front left it starts slow instead of fast and that seems to timeout. I saw a forum post of a guy getting a timeout error. So, I checked and the sensor LED does not come on. So I tested with a blade under the sensor and it came on. I could then redo leveling without restarting the printer. The next time I used the blade on the first try left front and it actually does not fail and continues doing probes when you use the blade.
How do I get it to reset to a fast/slow for every probe point?
Did I perhaps do something wrong in my Configuration.h or Configuration_adv.h files that would cause that?
