Problem bei kompilieren von Marlin : SKR 2.0 und Creality CR10 V2 June 07, 2021 07:44PM |
.... Compiling .pio\build\BIGTREE_SKR_2\src\src\gcode\host\M110.cpp.o Compiling .pio\build\BIGTREE_SKR_2\src\src\gcode\host\M113.cpp.o Compiling .pio\build\BIGTREE_SKR_2\src\src\gcode\host\M114.cpp.o Compiling .pio\build\BIGTREE_SKR_2\src\src\gcode\host\M115.cpp.o Marlin\src\gcode\gcode.cpp:216:8: error: no declaration matches 'void GcodeSuite::event_probe_recover()' 216 | void GcodeSuite::event_probe_recover() { | ^~~~~~~~~~ Marlin\src\gcode\gcode.cpp:216:8: note: no functions named 'void GcodeSuite::event_probe_recover()' In file included from Marlin\src\gcode\gcode.cpp:28: Marlin\src\gcode\gcode.h:321:7: note: 'class GcodeSuite' defined here 321 | class GcodeSuite { | ^~~~~~~~~~ Compiling .pio\build\BIGTREE_SKR_2\src\src\gcode\host\M118.cpp.o Marlin\src\gcode\gcode.cpp:230:8: error: no declaration matches 'void GcodeSuite::event_probe_failure()' 230 | void GcodeSuite::event_probe_failure() { | ^~~~~~~~~~ Marlin\src\gcode\gcode.cpp:230:8: note: no functions named 'void GcodeSuite::event_probe_failure()' In file included from Marlin\src\gcode\gcode.cpp:28: Marlin\src\gcode\gcode.h:321:7: note: 'class GcodeSuite' defined here 321 | class GcodeSuite { | ^~~~~~~~~~ Marlin\src\gcode\gcode.cpp:249:8: error: no declaration matches 'void GcodeSuite::G29_with_retry()' 249 | void GcodeSuite::G29_with_retry() { | ^~~~~~~~~~ Marlin\src\gcode\gcode.cpp:249:8: note: no functions named 'void GcodeSuite::G29_with_retry()' In file included from Marlin\src\gcode\gcode.cpp:28: Marlin\src\gcode\gcode.h:321:7: note: 'class GcodeSuite' defined here 321 | class GcodeSuite { | ^~~~~~~~~~ *** [.pio\build\BIGTREE_SKR_2\src\src\gcode\gcode.cpp.o] Error 1 In file included from Marlin\src\gcode\geometry\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\geometry\../../inc/../pins/pins.h:604, from Marlin\src\gcode\geometry\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\geometry\../gcode.h:306, from Marlin\src\gcode\geometry\G92.cpp:23: Marlin\src\gcode\geometry\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\geometry\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\geometry\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\geometry\../gcode.h:306, from Marlin\src\gcode\geometry\G92.cpp:23: Marlin\src\gcode\geometry\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | In file included from Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\host\../../inc/../pins/pins.h:604, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M110.cpp:23: Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\host\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M110.cpp:23: Marlin\src\gcode\host\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | In file included from Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\host\../../inc/../pins/pins.h:604, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\host\M113.cpp:23: Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\host\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\host\M113.cpp:23: Marlin\src\gcode\host\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | In file included from Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\host\../../inc/../pins/pins.h:604, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\host\M114.cpp:23: Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\host\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\host\M114.cpp:23: Marlin\src\gcode\host\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | In file included from Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\host\../../inc/../pins/pins.h:604, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M115.cpp:23: Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\host\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M115.cpp:23: Marlin\src\gcode\host\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | In file included from Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_REV_B.h:26, from Marlin\src\gcode\host\../../inc/../pins/pins.h:604, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:34, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M118.cpp:23: Marlin\src\gcode\host\../../inc/../pins/stm32f4/pins_BTT_SKR_V2_0_common.h:139: warning: "FIL_RUNOUT_PIN" redefined 139 | #define FIL_RUNOUT_PIN PC2 // E0DET | In file included from Marlin\src\gcode\host\../../inc/MarlinConfigPre.h:39, from Marlin\src\gcode\host\../../inc/MarlinConfig.h:28, from Marlin\src\gcode\host\../gcode.h:306, from Marlin\src\gcode\host\M118.cpp:23: Marlin\src\gcode\host\../../inc/../../Configuration.h:1318: note: this is the location of the previous definition 1318 | #define FIL_RUNOUT_PIN 2 // Creality CR10-S stock sensor | ========================================================== [[color=#FF0000]FAILED[/color]] Took 62.46 seconds ========================================================== Environment Status Duration ------------- -------- ------------ BIGTREE_SKR_2 FAILED 00:01:02.460 ===================================================== 1 failed, 0 succeeded in 00:01:02.460 =====================================================The terminal process "C:\Users\MSI GT72S\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1. Terminal will be reused by tasks, press any key to close it.
Re: Problem bei kompilieren von Marlin : SKR 2.0 und Creality CR10 V2 June 07, 2021 08:43PM |
Admin Registered: 14 years ago Posts: 7,284 |
Re: Problem bei kompilieren von Marlin : SKR 2.0 und Creality CR10 V2 June 08, 2021 04:45PM |
