Z not moving after Marlin 2.x upgrade
Posted by morpheus852
August 23, 2021 04:22AM
I just updated my febtop optimus p1 to Marlin 2.x. However the z axis isn't moving. As soon as I upload the old firmware, it's working again flawlessly. I'm not quite sure, what I'm missing here. Do you have any hints?
I already tried activating/ deactivating #define Z_DRIVER_TYPE TMC2208. In the 1.9 firmware it's not used at all.
Do you need any other information to help troubleshooting ? I've attached version 2.x and 1.9 configuration.h
Furthermore, Y axis sounds quite "mechanical", as if it's moving not correctly with a wrong frequency or so. X axis is moving just fine.
open | download - Configuration_1_9.h (72.5 KB)
open | download - Configuration_2_0.h (104.9 KB)
VDX
Re: Z not moving after Marlin 2.x upgrade
August 23, 2021 04:30AM
... check for same pins settings in the "pins.h" file ...
Viktor
August 23, 2021 05:04AM
I assume from the "#define MOTHERBOARD BOARD_RAMPS_14_EFB" it will use the pins_ramps.h. I compared both files, but couldn't see any major differences in pin settings. Anything I should look for in particular?
open | download - pins_RAMPS_2_0.h (24.3 KB)
open | download - pins_RAMPS_1_9.h (15.3 KB)
VDX
August 23, 2021 05:34AM
... in the " pins_RAMPS_2_0.h" there is this "#ifndef Z_STEP_PIN" for defining the pin ... can you verify, that its value is 46 after start? -- could be predefined elsewhere on another pin value.
#ifndef Z_STEP_PIN
  #define Z_STEP_PIN        46
Other then this, the behaviour and driver controlling could be different in other methodes too ... or you've not set a specific flag for your actual setup ...
Viktor
August 23, 2021 05:52AM
M43 output seem to be fine:
PIN: 46 Port: L3 Z_STEP_PIN protected
Another thing I just realized, it feels like, the 2 Z stepper motors actually try to move the bed, because I feel a tiny vibration, as if there is not enough current on it or so.
what do you exactly mean by "Other then this, the behaviour and driver controlling could be different in other methodes too ... or you've not set a specific flag for your actual setup ..."?
VDX
August 23, 2021 06:23AM
... could be, steps/mm value way too high and/or current not high enough ...
Viktor
August 23, 2021 07:04AM
I kinda doubt the steps/mm, because they are the same as in 1.9 : #define DEFAULT_AXIS_STEPS_PER_UNIT { 80,160,2560, 190 }. About the current I'm not so sure about, on 2.x the M906 reports:
SENDING:M906
X driver current: 800
Y driver current: 800
Z driver current: 800
E driver current: 800
But in the old version, the command isn't available. Any other possibilities to check the current settings?
VDX
August 23, 2021 08:44AM
... are the two Z-drivers arranged serial or parallel?
Viktor
August 23, 2021 09:32AM
Not sure, I opened the control box, seems like, there is only one Z driver, see the picture. Or it uses some giant stepper drivers below of the board?
Couldn't upload the picture here, so using an imgur link: [imgur.com]
August 23, 2021 10:05AM
External driver like that are notoriously slow
you have #define Z_DRIVER_TYPE TMC2208 which is a very quick stepper driver
Try #define Z_DRIVER_TYPE A4988
August 23, 2021 01:03PM
Thanks for the input. Unfortunately it doesn't change anything, still not moving :-)
August 23, 2021 08:42PM
Well the wiring of the external drivers makes me think that the enable should be inverted
It is not in the original config.
but give
#define Z_ENABLE_ON 1
a try
August 23, 2021 09:51PM
I would try the DEFAULT_MAX_FEEDRATE from 5 to 2 or maybe 3
#define DEFAULT_MAX_FEEDRATE { 300, 300, 2, 25 }
I noted you are using a MKS Gen controller, though selecting Ramps
Myself would select MKS related code. This allows for "EFBE" / " EFBF " just a suggestion.
This allows my 3D Printers to have control of dual variable fan for Cooling "Model / Hot-End" the other Cooling "Controller / Stepper Motor Drivers "
#define MOTHERBOARD BOARD_MKS_BASE_14
Edited 1 time(s). Last edit at 08/23/2021 09:52PM by Roberts_Clif.
August 23, 2021 11:33PM
From what I can see in the image
X stepper driver I don't recognize, perhaps there is more information on the underside of the module.
Y and E seems to be a DRV8825
Z is the external drivers via a MKS CD 57/86 stepper motor driver expansion board
So why are all stepper drivers set to tmc2208?
Can you take pictures of the external stepper drivers, any identifying marks?
Can you take images of the underside of the X stepper driver?
Do the Z stepper motors get energized. (ie become electrically locked in position, no longer free to rotate) ?
As this indicates if the enable pin is working or not
Direct link to image
Edited 3 time(s). Last edit at 08/23/2021 11:57PM by Dust.
August 24, 2021 07:00AM
Dust
but give
a try
I gave it a try, no success!
August 24, 2021 07:02AM
Roberts_Clif
I tried the Z feedrate with 2, still didn't move at all.
And okay, I'll change the motherboard to #define MOTHERBOARD BOARD_MKS_BASE_14, but I guess I'll have to go through all PIN settings. I haven't changed it because in the old original firmware from the manufacturer it was set to BOARD_RAMPS_14_EFB, but sure, worth a shot!
August 24, 2021 07:06AM
Dust
Thanks, I thought as much, that these don't look like TMC2208, have had a first look at the controlbox yesterday too, the reason for TMC2208 was simply, because the manufacturer claimed to use them ;-)
I'll take a picture as soon as I can.
And yes, the Z stepper motors get energized. They get locked in position, quite a bit actually as the bed is heavy could be pushed down with just a few gramms.
Also a big thanks to all of you for helping !
August 24, 2021 10:33AM
So, here are all axis drivers:
[imgur.com]
Seems to me, that only the X axis uses a tmc2208.
August 24, 2021 11:30AM
Yes X is a TMC2208
Y is a DRV8825
Z is a stm32 based stepper controller apparently doing 1/128 micro stepping
E is a DRV8825
re looking at the images, the red wire from the MKS CD 57/86 stepper motor driver expansion board, it doesn't go anywhere does it? it just ends?
With the wiring diagram, with the red wire disconnected that means the Z steppers are always enabled, so we can forget about the z stepper enable io line.
I don't see any obvious reason for Z not to work..
So im back to thinking this stepper driver is slow.
try #define Z_DRIVER_TYPE TB6560
that is the slowest driver marlin has pre configured..
August 24, 2021 01:27PM
YES! grinning smiley That's it! Changing to TB6560 was a success! It finally moves.
Also I set Y and E to DRV8825.
Really really nice! Thank you so much! Now I can finally go further, I'm so happy now.
August 24, 2021 10:12PM
Well we now know that it is signalling speed.
We tried A4988 and it didn't work
We tried TB6560 and it did.
There are two other options between those two speeds DRV8825 and TB6600
You should try them also to find the fastest one that still works,
In order fastest to slowest
* 500000 : Maximum for A4988 stepper driver
* 250000 : Maximum for DRV8825 stepper driver
* 150000 : Maximum for TB6600 stepper driver
* 15000 : Maximum for TB6560 stepper driver
August 25, 2021 03:31AM
Will try those other two options too!
Perhaps another quick question: Z keeps crashing into the nozzle after starting a print and trying to do command G28, sliced with PrusaSlicer and start gcode is:
M82 ;absolute extrusion mode
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
M109 S[first_layer_temperature] ; Wait for nozzle temp
G28 ; home all axes
G29
G1 X0 Y4 Z5 F3000
G92 E0 ;zero the extruded length
G1 E50 F200 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
M117 Printing...
However if I use the G28 directly, it triggers the Probe stop correctly. Could it be because of the G90 absolute positioning command?
Edit: issuing the g90 command, followed by g28 in the console is still doing the exact homing procedure..
I'll attach the most recent configuration.h and configuration_adv.h
Edited 1 time(s). Last edit at 08/25/2021 03:34AM by morpheus852.
open | download - Configuration.h (105.2 KB)
open | download - Configuration_adv.h (164.5 KB)
August 25, 2021 04:22AM
It may simply be missing z steps, as timing is not quite right yet.
Move Z out of the way. move z up 20, measure how far it moved., move z down 20, measure it. did it move the same 20mm in both directions?
August 25, 2021 10:08AM
Yes, it moves exactly 20 mm.
However, i felt lucky and just reflashed the firmware without changing a single line and now it's working, I don't know why. :-)
