rds
marlin bug fix 2.0 delta config
September 09, 2021 11:26AM
hi, i try to setup marlin for my delta 3d printer with octopus board. i copy delta config to "Configuration.h" and i was able to jog all 3 axis. my problem is after i homed all axis, i cant jog anymore (all 3 axis alway moving down same time when i jog any axis) but if i cycle power, i can jog single axis again without problem. anyone know how to fix this?
Edited 1 time(s). Last edit at 09/09/2021 11:27AM by rds.
Re: marlin bug fix 2.0 delta config
September 09, 2021 05:41PM
Could be a configuration problem, Please post your configuration.
rds
September 10, 2021 11:40AM
* Marlin 3D Printer Firmware
* Copyright (c) 2020 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
* Based on Sprinter and grbl.
* Copyright (c) 2011 Camiel Gubbels / Erik van der Zalm
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see [www.gnu.org].
#pragma once
* Configuration.h
* Basic settings such as:
* - Type of electronics
* - Type of temperature sensor
* - Printer geometry
* - Endstop configuration
* - LCD controller
* - Extra features
* Advanced settings can be found in Configuration_adv.h
#define CONFIGURATION_H_VERSION 02000901
//============================= Getting Started =============================
* Here are some useful links to help get your machine configured and calibrated:
* Example Configs: [github.com]
* Průša Calculator: [blog.prusaprinters.org]
* Calibration Guides: [reprap.org]
* [reprap.org]
* [sites.google.com]
* [youtu.be]
* Calibration Objects: [www.thingiverse.com]
* [www.thingiverse.com]
//========================== DELTA / SCARA / TPARA ==========================
// Download configurations from the link above and customize for your machine.
// Examples are located in config/examples/delta, .../SCARA, and .../TPARA.
// @section info
// Author info of this build printed to the host during boot and M115
#define STRING_CONFIG_H_AUTHOR "(BigTreeTech, Octopus)" // Who made the changes.
//#define CUSTOM_VERSION_FILE Version.h // Path from the root directory (no quotes)
* *** VENDORS PLEASE READ ***
* Marlin allows you to add a custom boot image for Graphical LCDs.
* With this option Marlin will first show your custom screen followed
* by the standard Marlin logo with version number and web URL.
* We encourage you to take advantage of this new feature and we also
* respectfully request that you retain the unmodified Marlin boot screen.
// Show the Marlin bootscreen on startup. ** ENABLE FOR PRODUCTION **
#define SHOW_BOOTSCREEN
// Show the bitmap in Marlin/_Bootscreen.h on startup.
//#define SHOW_CUSTOM_BOOTSCREEN
// Show the bitmap in Marlin/_Statusscreen.h on the status screen.
//#define CUSTOM_STATUS_SCREEN_IMAGE
// @section machine
* Select the serial port on the board to use for communication with the host.
* This allows the connection of wireless adapters (for instance) to non-default port pins.
* Serial port -1 is the USB emulated serial port, if available.
* Note: The first serial port (-1 or 0) will always be used by the Arduino bootloader.
* :[-1, 0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 1 // TFT
* Serial Port Baud Rate
* This is the default communication speed for all serial ports.
* Set the baud rate defaults for additional serial ports below.
* 250000 works in most cases, but you might try a lower speed if
* you commonly experience drop-outs during host printing.
* You may try up to 1000000 to speed up SD file transfer.
* :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000]
#define BAUDRATE 115200
//#define BAUD_RATE_GCODE // Enable G-code M575 to set the baud rate
* Select a secondary serial port on the board to use for communication with the host.
* Currently Ethernet (-2) is only supported on Teensy 4.1 boards.
* :[-2, -1, 0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT_2 -1 // USB
//#define BAUDRATE_2 250000 // Enable to override BAUDRATE
* Select a third serial port on the board to use for communication with the host.
* Currently only supported for AVR, DUE, LPC1768/9 and STM32/STM32F1
#define SERIAL_PORT_3 2 // RPI
//#define BAUDRATE_3 250000 // Enable to override BAUDRATE
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// Choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_BTT_OCTOPUS_V1_1
#endif
this is the octopus config file (cant copy full file, but it was origional marlin firmware for octopus)
below is the delta add to config (above the endstop setting)
//============================== Delta Settings =============================
// Enable DELTA kinematics and most of the default configuration for Deltas
#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 80
// After homing move down to a height where XY movement is unconstrained
#define DELTA_HOME_TO_SAFE_ZONE
// Delta calibration menu
// uncomment to add three points calibration menu option.
// See [minow.blogspot.com]
#define DELTA_CALIBRATION_MENU
// uncomment to add G33 Delta Auto-Calibration (Enable EEPROM_SETTINGS to store results)
#if ANYCUBIC_PROBE_VERSION > 0
#define DELTA_AUTO_CALIBRATION
#endif
// NOTE NB all values for DELTA_* values MUST be floating point, so always have a decimal point in them
#if ENABLED(DELTA_AUTO_CALIBRATION)
// set the default number of probe points : n*n (1 -> 7)
#define DELTA_CALIBRATION_DEFAULT_POINTS 4
#endif
#if EITHER(DELTA_AUTO_CALIBRATION, DELTA_CALIBRATION_MENU)
// Set the steprate for papertest probing
#define PROBE_MANUALLY_STEP 0.05 // (mm)
#endif
#if ENABLED(ANYCUBIC_KOSSEL_PLUS)
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 120.0 // (mm)
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 267.0 // (mm)
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 186.0 // (mm)
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 31.0 // (mm)
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 20.6 // (mm)
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-(DELTA_EFFECTOR_OFFSET)-(DELTA_CARRIAGE_OFFSET)) // (mm) Get this value from G33 auto calibrate
#else
#define DELTA_PRINTABLE_RADIUS 90.0 // (mm)
#define DELTA_DIAGONAL_ROD 218.0 // (mm)
#define DELTA_RADIUS 97.0 // (mm) Get this value from G33 auto calibrate
#endif
// Distance between bed and nozzle Z home position
#define DELTA_HEIGHT 300.00 // (mm) Get this value from G33 auto calibrate
#define DELTA_ENDSTOP_ADJ { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate
// Trim adjustments for individual towers
// tower angle corrections for X and Y tower / rotate XYZ so Z tower angle = 0
// measured in degrees anticlockwise looking from above the printer
#define DELTA_TOWER_ANGLE_TRIM { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate
// Delta radius and diagonal rod adjustments (mm)
//#define DELTA_RADIUS_TRIM_TOWER { 0.0, 0.0, 0.0 }
//#define DELTA_DIAGONAL_ROD_TRIM_TOWER { 0.0, 0.0, 0.0 }
#endif
