I need help building for Elegoo Neptune 2 October 05, 2021 08:13PM |
platformio run -e mks_robin_nano_v3_usb_flash_drive ; echo "done" >|/var/folders/ft/vf81114d3xqdjj89xh9d5z5c0000gn/T/ipc [email protected] Mks-Robin-Nano-Marlin2.0-Firmware % platformio run -e mks_robin_nano_v3_usb_flash_drive ; echo "done" >|/var/folders/ft/vf81114d3xqdjj89xh9d5z5c0000gn/T/ipc Processing mks_robin_nano_v3_usb_flash_drive (platform: [email protected]~12.0; board: marlin_STM32F407VGT6_CCM; framework: arduino) ---------------------------------------------------------------------------------------------------------------------------------------- Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: [docs.platformio.org] PLATFORM: ST STM32 (12.0.0) > STM32F407VG (128k RAM, 64k CCM RAM, 1024k Flash HARDWARE: STM32F407VGT6 168MHz, 128KB RAM, 1MB Flash DEBUG: Current (jlink) External (jlink, stlink) PACKAGES: - framework-arduinoststm32 0.0.0 - framework-cmsis 2.50501.200527 (5.5.1) - toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1) Converting Marlin.ino LDF: Library Dependency Finder -> [bit.ly] LDF Modes: Finder ~ chain, Compatibility ~ soft Found 13 compatible libraries Scanning dependencies... Dependency Graph |-- 6.1.1 |-- 0.0.0+20201117144502 |-- 0.7.3 | |-- 1.0 | |-- 1.0 |-- 1.0 |-- 1.1.2 |-- 1.0 |-- 1.0.0 |-- 1.0 |-- 2.0.1 Building in release mode Checking size .pio/build/mks_robin_nano_v3_usb_flash_drive/firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [===== ] 46.8% (used 61280 bytes from 131072 bytes) Flash: [==== ] 36.9% (used 387296 bytes from 1048576 bytes) ===================================================== [SUCCESS] Took 10.30 seconds ===================================================== Environment Status Duration --------------------------------- -------- ------------ mks_robin_nano_v3_usb_flash_drive SUCCESS 00:00:10.298 ===================================================== 1
Re: I need help building for Elegoo Neptune 2 October 06, 2021 02:16AM |
Admin Registered: 14 years ago Posts: 13,568 |
Re: I need help building for Elegoo Neptune 2 October 06, 2021 08:36AM |
Admin Registered: 11 years ago Posts: 6,538 |
Re: I need help building for Elegoo Neptune 2 October 06, 2021 08:42AM |
Re: I need help building for Elegoo Neptune 2 October 06, 2021 01:34PM |
// Safety: The probe needs time to recognize the command. // Minimum command delay (ms). Enable and increase if needed. #define BLTOUCH_DELAY 500 /** * Settings for BLTOUCH Classic 1.2, 1.3 or BLTouch Smart 1.0, 2.0, 2.2, 3.0, 3.1, and most clones: */ // Feature: Switch into SW mode after a deploy. It makes the output pulse longer. Can be useful // in special cases, like noisy or filtered input configurations. #define BLTOUCH_FORCE_SW_MODE. in Configuration_adv.h but it still does the same thing.
Re: I need help building for Elegoo Neptune 2 October 06, 2021 07:10PM |
Re: I need help building for Elegoo Neptune 2 October 18, 2021 11:03PM |
