Strange issue with Marlin and G34
Posted by ss002d6252
October 16, 2021 05:36PM
I have a strange issue where the G34 command causes the dual Z steppers to diverge rather than converge whilst running.
The Z motors work absolutely spot on but I can't figure out why G34 seems content to move the steppers apart rather than converge the measurements in order to level the axis.
I've tried flipping motors around. Flashed Marlin to a different version etc but I still can't figure out why it's doing this.
Does anyone have any ideas ?
Thanks.
Re: Strange issue with Marlin and G34
October 17, 2021 07:44AM
I had a similar problem I had entered the axis coordinates wrongly in Configuration_adv.h
October 17, 2021 09:10AM
Nikki81
Thanks. I'll take a closer look at that and see what if I can spot something.
October 17, 2021 10:31AM
For reference managed to sort it.
I swapped the two motors over on the board - just switched the Z1 wiring to Z2 and Z2 wiring to Z1, and for some unknown reason that works thumbs up . Not sure at all why, but it worked. Must be something in the code.
Edited 1 time(s). Last edit at 10/17/2021 11:02AM by ss002d6252.
VDX
October 17, 2021 11:08AM
... the direction of the steppers can be changed by switching the wires of one solenoid or by "mirroring" the plug - so you eventually rearranged them, so it's for better now smoking smiley
Viktor
October 17, 2021 11:42AM
The odd thing is that it wasn't anything to do with reversing the motor direction. All that had already been tried , in multiple combinations.
There was no problem with controlling Z in the right direction, only when using G34 was it working wrongly.
I literally just swapped the entire wiring, in exactly the same wiring order, from Z1 to Z2 (and Z2 to Z1) on the board. Bizarre, but it worked.
