SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 01:41AM |
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 02:10AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 02:19AM |
Admin Registered: 13 years ago Posts: 7,001 |
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 // :{ 0:'Low', 1:'High' } #define X_ENABLE_ON 0
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 06:13PM |
VDX
... I'm regularly using external drivers with my boards with Marlin4Due oder Marlin2.0 on them -- it's mainly defining the correct pins for STEP and DIR (sometimes Enable too), connecting them together with GND to the inputs of the driver (signal pins to [+], GND to [-] of the driver).
Could be, you have to set pullup resistors, which my boards have installed ... and some drivers needs at less 2ms step-pulse duration to detect a step ...
Dust
Make sure to force the sdcard to use the onboard sdcard if it defaults to the lcd it sets up the SPI pins on exp1/exp2 and wrecks your day
Also check the enable pin. Marln by default expects active low. But most people when they wire the external stepper driver make it active high.
ie
READ: PIN: PE11 M42 P75 E0_ENABLE_PIN Output = 1 READ: PIN: PE12 M42 P76 E0_DIR_PIN Output = 0 READ: PIN: PE13 M42 P77 E0_STEP_PIN Output = 0
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 08:04PM |
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 11, 2021 09:14PM |
Re: SKR 2 or SKR 1.4 with MA860H External Stepper Driver November 23, 2021 07:04PM |
