I bricked my mainboard, MKS GEN L v1. So I ordered a new one and installed it.
When testing everything, I found that the endstops (all 3) are ignored by the firmware. Means I have moved the head via the display controls, blocked the switch with some metal, the switche's LED went red, but the head still moved in its direction.
My firmware is the latest from Github, only with modifications for a different extruder (Hemera).
So, having no better ideas, I tried the orig. HEX file from Evnovo, installed it and, voila, it worked. Head doesn't move towards the switch any more when blocked.
But the Hemera-modified FW also worked until now!
Any idea how this could happen? Is it maybe a difference if the head is driven via the display or via USB?
Here is the only difference I found in the supposedly relevant config section:
orig:
#define ENDSTOP_NOISE_FILTER
Github:
#define ENDSTOP_NOISE_THRESHOLD 2
AFAIK the orig. FW is Marlin 1, while the Github one is v2, so I suspect these settings are doing the same thing and can't cause the described issue, can it?
