I found that if you want to get the best out of Octoprint then you should not use the minimum components.
Note Right Model below vs the Left Model
I was using Raspberry Pi 2 this Pi does not have the power required to 3D Print while using Octolapse add-on feature in Octoprint.
Using a faster Raspberry pi with Octoprint will eliminate the fuzzy exterior texture.
