SKR1.4 Turbo Dual X axes X2 not shown on M122
Posted by jortijn
December 26, 2021 03:04PM
Hi All,
I have spent many hours trying to find what my issue X2 is not detected, I have TMC2209 and the drivers seem to work fine if I swap them they get detected.
Latest Marlin 2.0.9.3 version and earlier versions with same result.
Board BOARD_BTT_SKR_V1_4_TURBO
drivers: TMC2209
X2 is on E1 port
When I enable X_DUAL_STEPPER_DRIVERS the X2 is moving both X and X2 (even it seems to run on a different micro steps) but when I do a M122 it only shows X not X2 so I can't setup the current for X2
See M112
ENDING:M122
axis:pwm_scale/curr_scale/mech_load|flags|warncount
X Y Z
Address 0 0 0
Enabled false false false
Set current 900 800 800
and a bit later
Testing X connection... OK
Testing Y connection... OK
Testing Z connection... OK
but nothing about X2 or E1
Please find my configuration and configuration_adv attached I can't figure out why X2 is not showing.
Kind regards,
Jortijn
open | download - Configuration.h (108.8 KB)
open | download - Configuration_adv.h (171.8 KB)
Re: SKR1.4 Turbo Dual X axes X2 not shown on M122
December 26, 2021 05:45PM
Using your configuration files + #define SERIAL_PORT -1 so I can talk to it.
Produces the expected results (I dont have tmc2208/9's plugged in)
11:43:19.317 > Testing X connection... Error: All LOW
11:43:19.337 > Testing X2 connection... Error: All LOW
11:43:19.358 > Testing Y connection... Error: All LOW
11:43:19.379 > Testing Z connection... Error: All LOW
11:43:19.400 > ok
December 27, 2021 02:33AM
Hi Dust,
Thank you for testing that it made me realise my SD card was not inserted bit of a rooky mistake not sure why it didn't throw an error as now I have removed the card again I can't get it to upload without
Much apricated for giving me feedback it helped me massively.
Kind regards,
Jortijn
