corexy sensorless probing
February 23, 2022 04:28PM
hello
ant idea how configure a sensorless probing in a corexy printer with tmc?
Now I am able to configure a sensorless homing with success.
Re: corexy sensorless probing
July 08, 2022 10:02AM
i got the same issues:
Machine Type: CoreCartesian
Probe:
Probe Offset X0.00 Y0.00 Z2.00 (Aligned With & Above Nozzle)
Auto Bed Leveling: BILINEAR (disabled)
current_position= X0.00 Y0.00 Z5.00 : Probe::set_deployed
deploy: 1
Probe::do_z_raise(5.00)
>>> do_blocking_move_to X0.00 Y0.00 Z5.00
> X0.00 Y0.00 Z5.00
<<< do_blocking_move_to X0.00 Y0.00 Z5.00
> X0.00 Y0.00 Z5.00
reset_bed_level
>>> Probe::probe_at_point X0.00 Y0.00 Z5.00
...(0.00, 0.00, raise, 0, probe_relative)
> X0.00 Y0.00 Z5.00
deploy: 1
>>> Probe::run_z_probe X0.00 Y0.00 Z5.00
>>> Probe::probe_down_to_z X0.00 Y0.00 Z5.00
> X0.00 Y0.00 Z-10.00
<<< do_blocking_move_to X0.00 Y0.00 Z-10.00
current_position= X0.00 Y0.00 Z5.00 : sync_plan_position
<<< Probe::probe_down_to_z X0.00 Y0.00 Z5.00
SLOW Probe fail! - Triggered early.
<<< Probe::run_z_probe X0.00 Y0.00 Z5.00
deploy: 0
> X0.00 Y0.00 Z5.00
> X0.00 Y0.00 Z5.00
Errortongue sticking out smileyrobing Failed
[ERROR] Errortongue sticking out smileyrobing Failed
what to do'?
July 08, 2022 12:11PM
Please attach your configuration files.
Please verify if I have the following correct or not:
  • Sensorless homing is enabled and is working reliably.
  • Homing Z to Z min.
  • Probing fails per the log you posted.
Do you probe at the same feed rate as you home? Don't know if it makes a difference or not but if homing is reliable you may want to use that feed rate as your Z_PROBE_FEEDRATE_SLOW.
