Bed leveling not working (TMC2130/PINDA sensor) March 13, 2022 02:40PM |
Connecting... Printer is now online. >>> m111 s32 SENDING:M111 S32 echoEBUG:LEVELING >>> G28 X0.00 Y-2.20 Z0.20 Machine Type: Cartesian Probe: FIX_MOUNTED_PROBE Probe Offset X23.00 Y5.00 Z0.30 (Right-Back & Above Nozzle) Auto Bed Leveling: BILINEAR (disabled) X current: 500 -> 250 Y current: 600 -> 300 Raise Z (before homing) by 2.00 >>> do_blocking_move_to X0.00 Y-2.20 Z0.20 > X0.00 Y-2.20 Z2.00 <<< do_blocking_move_to X0.00 Y-2.20 Z2.00 >>> homeaxis(X) Home Fast: -382.50mm >>> do_homing_move X0.00 Y-2.20 Z2.00 ...(X, -382.50, [50.00]) <<< do_homing_move X0.00 Y-2.20 Z2.00 >>> set_axis_is_at_home(X) Axis X home_offset = 0.00 position_shift = 0.00 > home_offset[X] = 0.00 current_position= X0.00 Y-2.20 Z2.00 : <<< set_axis_is_at_home(X) current_position= X0.00 Y-2.20 Z2.00 : sync_plan_position current_position= X0.00 Y-2.20 Z2.00 : > AFTER set_axis_is_at_home <<< homeaxis(X) >>> homeaxis(Y) Home Fast: -324.75mm >>> do_homing_move X2.00 Y-2.20 Z2.00 ...(Y, -324.75, [50.00]) <<< do_homing_move X2.00 Y-2.20 Z2.00 >>> set_axis_is_at_home(Y) Axis Y home_offset = 0.00 position_shift = 0.00 > home_offset[Y] = 0.00 current_position= X2.00 Y-2.20 Z2.00 : <<< set_axis_is_at_home(Y) current_position= X2.00 Y-2.20 Z2.00 : sync_plan_position current_position= X2.00 Y-2.20 Z2.00 : > AFTER set_axis_is_at_home <<< homeaxis(Y) >>> home_z_safely X2.00 Y-0.20 Z2.00 current_position= X2.00 Y-0.20 Z2.00 : sync_plan_position destination= X104.00 Y101.25 Z0.00 : home_z_safely >>> do_blocking_move_to X2.00 Y-0.20 Z2.00 > X104.00 Y101.25 Z2.00 echo:busy: processing <<< do_blocking_move_to X104.00 Y101.25 Z2.00 >>> homeaxis(Z) current_position= X104.00 Y101.25 Z2.00 : Probe::set_deployed deploy: 1 Probe::do_z_raise(2.00) >>> do_blocking_move_to X104.00 Y101.25 Z2.00 > X104.00 Y101.25 Z2.00 <<< do_blocking_move_to X104.00 Y101.25 Z2.00 >>> do_blocking_move_to X104.00 Y101.25 Z2.00 > X104.00 Y101.25 Z2.00 <<< do_blocking_move_to X104.00 Y101.25 Z2.00 Home Fast: -315.00mm >>> do_homing_move X104.00 Y101.25 Z2.00 ...(Z, -315.00, [5.00]) echo:busy: processing <<< do_homing_move X104.00 Y101.25 Z2.00 Move Away: 2.00mm >>> do_homing_move X104.00 Y101.25 Z2.00 ...(Z, 2.00, 20.00) <<< do_homing_move X104.00 Y101.25 Z2.00 Re-bump: -4.00mm >>> do_homing_move X104.00 Y101.25 Z2.00 ...(Z, -4.00, 10.00) <<< do_homing_move X104.00 Y101.25 Z2.00 >>> set_axis_is_at_home(Z) *** Z HOMED WITH PROBE (Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN) *** > probe.offset.z = 0.30 Axis Z home_offset = 0.00 position_shift = 0.00 > home_offset[Z] = 0.00 current_position= X104.00 Y101.25 Z-0.10 : <<< set_axis_is_at_home(Z) current_position= X104.00 Y101.25 Z-0.10 : sync_plan_position current_position= X104.00 Y101.25 Z-0.10 : > AFTER set_axis_is_at_home current_position= X104.00 Y101.25 Z-0.10 : Probe::set_deployed deploy: 0 >>> do_blocking_move_to X104.00 Y101.25 Z-0.10 > X104.00 Y101.25 Z-0.10 <<< do_blocking_move_to X104.00 Y101.25 Z-0.10 <<< homeaxis(Z) <<< home_z_safely X104.00 Y101.25 Z1.90 current_position= X104.00 Y101.25 Z1.90 : sync_plan_position current_position= X104.00 Y101.25 Z1.90 : Leveling OFF current_position= X104.00 Y101.25 Z0.00 : ...Now ON current_position= X104.00 Y101.25 Z0.00 : sync_plan_position Restore driver current... <<< G28 X104.00 Y101.25 Z0.00 >>> G29 X104.00 Y101.25 Z0.00 Machine Type: Cartesian Probe: FIX_MOUNTED_PROBE Probe Offset X23.00 Y5.00 Z0.30 (Right-Back & Above Nozzle) Auto Bed Leveling: BILINEAR (enabled) Z Fade: 10.00 ABL Adjustment Z 0.000 ( 0.000) Preheating hotend (160) and bed (50) Wait for bed heating... echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing current_position= X104.00 Y101.25 Z0.00 : Leveling ON current_position= X104.00 Y101.25 Z0.00 : ...Now OFF current_position= X104.00 Y101.25 Z0.00 : sync_plan_position current_position= X104.00 Y101.25 Z0.00 : Probe::set_deployed deploy: 1 Probe::do_z_raise(2.00) >>> do_blocking_move_to X104.00 Y101.25 Z0.00 > X104.00 Y101.25 Z2.00 <<< do_blocking_move_to X104.00 Y101.25 Z0.00 >>> do_blocking_move_to X104.00 Y101.25 Z0.00 > X104.00 Y101.25 Z0.00 <<< do_blocking_move_to X104.00 Y101.25 Z0.00 >>> Probe::probe_at_point X104.00 Y101.25 Z0.00 ...(23.00, 10.00, raise, 0, probe_relative) current_position= X104.00 Y101.25 Z0.00 : >>> do_blocking_move_to X104.00 Y101.25 Z0.00 > X0.00 Y5.00 Z0.00 <<< do_blocking_move_to X0.00 Y5.00 Z0.00 current_position= X0.00 Y5.00 Z0.00 : Probe::set_deployed deploy: 1 >>> Probe::run_z_probe X0.00 Y5.00 Z0.00 >>> Probe::probe_down_to_z X0.00 Y5.00 Z0.00 >>> do_blocking_move_to X0.00 Y5.00 Z0.00 > X0.00 Y5.00 Z-2.30 <<< do_blocking_move_to X0.00 Y5.00 Z0.00 current_position= X0.00 Y5.00 Z0.00 : sync_plan_position <<< Probe::probe_down_to_z X0.00 Y5.00 Z0.00 SLOW Probe fail! - No trigger. <<< Probe::run_z_probe X0.00 Y5.00 Z0.00 current_position= X0.00 Y5.00 Z0.00 : Probe::set_deployed deploy: 0 >>> do_blocking_move_to X0.00 Y5.00 Z0.00 > X0.00 Y5.00 Z0.00 <<< do_blocking_move_to X0.00 Y5.00 Z0.00 Error
robing Failed [ERROR] Error
robing Failed <<< Probe::probe_at_point X0.00 Y5.00 Z0.00 current_position= X0.00 Y5.00 Z0.00 : Leveling OFF current_position= X0.00 Y5.00 Z0.00 : ...Now ON current_position= X0.00 Y5.00 Z0.00 : sync_plan_position current_position= X0.00 Y5.00 Z0.00 : Probe::set_deployed deploy: 0 current_position= X0.00 Y5.00 Z0.00 : > probing complete current_position= X0.00 Y5.00 Z0.00 : sync_plan_position <<< G29 X0.00 Y5.00 Z0.00
Re: Bed leveling not working (TMC2130/PINDA sensor) March 28, 2022 10:36PM |
