Marlin 2.0.9.3 & Build surface alignment March 22, 2022 06:26PM |
Auto leveling, seems to fall part way on the bed and part way off. It will not measure Positive Y (forward) of the center of the Bed, It fails trying to measure air.|
Re: Marlin 2.0.9.3 & Build surface alignment March 22, 2022 06:34PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 22, 2022 07:37PM |
Admin Registered: 14 years ago Posts: 7,284 |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 04:55PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 05:50PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 06:43PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 07:20PM |
#define Z_SAFE_HOMING_X_POINT X_CENTER // X point for Z homing #define Z_SAFE_HOMING_Y_POINT Y_CENTER + 25 // Y point for Z homing
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 07:57PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 09:19PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 09:23PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 09:35PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 23, 2022 09:43PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 24, 2022 07:53PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 25, 2022 09:59PM |
Re: Marlin 2.0.9.3 & Build surface alignment March 26, 2022 02:14AM |
Re: Marlin 2.0.9.3 & Build surface alignment March 27, 2022 09:40AM |
Re: Marlin 2.0.9.3 & Build surface alignment March 27, 2022 06:54PM |
Mr Kroll
Thankyou dust, It is nice to know the correct way to configure this part of Marlin.
Several small adjustments to the firmware,
A New BL Touch Sensor,
And a few mechanical tweaks later,
The machine has stabilized.
( I hate it when things don't just work smoothly)
Is a Y Positive command supposed to move the build plate toward the operator during use?
Re: Marlin 2.0.9.3 & Build surface alignment April 01, 2022 09:12PM |
Re: Marlin 2.0.9.3 & Build surface alignment April 01, 2022 10:22PM |
Re: Marlin 2.0.9.3 & Build surface alignment April 02, 2022 01:24PM |
Re: Marlin 2.0.9.3 & Build surface alignment June 16, 2022 03:06PM |
Dust
Step 1) is to make sure your bed is defined correctly. See [manuelmclure.github.io]
Ie when you home then G1X0Y0 the hotend is over the X0 Y0 position of the bed
Safe Z homing moves the PROBE to the center of your headed bed (not the hotend). This requires that probe offsets are set correctly as well as X0 Y0
