LCD menu slow when selecting a file to print on SD card April 08, 2022 11:32AM |
Re: LCD menu slow when selecting a file to print on SD card April 08, 2022 01:14PM |
// Setting are adjusted for My LCD #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 2 //Including lines to reverse direction //#define REVERSE_ENCODER_DIRECTION //#define REVERSE_MENU_DIRECTION
Re: LCD menu slow when selecting a file to print on SD card April 08, 2022 02:00PM |
Re: LCD menu slow when selecting a file to print on SD card April 08, 2022 08:50PM |
Re: LCD menu slow when selecting a file to print on SD card April 09, 2022 08:14AM |
SDCARD_SORT_ALPHA SDSORT_USES_RAM true SDSORT_CACHE_NAMES true
Re: LCD menu slow when selecting a file to print on SD card April 09, 2022 12:07PM |
Re: LCD menu slow when selecting a file to print on SD card April 09, 2022 12:40PM |
[email protected]
Try enabling the following.
Re: LCD menu slow when selecting a file to print on SD card April 09, 2022 01:34PM |
Re: LCD menu slow when selecting a file to print on SD card April 10, 2022 09:39AM |
[email protected]
It may be reading the SD card each time you click which will noticeably slow things down.
Try enabling the following. The directory gets moved into RAM which really speeds things up. The only downside is you may run out of RAM on the 8 bit controllers.
