Ender 3 Pro & Creality filament detection sensor issue May 13, 2022 11:24PM |
Re: Ender 3 Pro & Creality filament detection sensor issue May 14, 2022 08:38AM |
#define FILAMENT_RUNOUT_SENSOR #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_PIN 19 // Hictop printer, from pins_RAMPS.h
Re: Ender 3 Pro & Creality filament detection sensor issue May 14, 2022 10:50AM |
Re: Ender 3 Pro & Creality filament detection sensor issue May 14, 2022 01:16PM |
Re: Ender 3 Pro & Creality filament detection sensor issue May 14, 2022 09:48PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Ender 3 Pro & Creality filament detection sensor issue May 15, 2022 12:19PM |
#define FILAMENT_RUNOUT_SENSOR #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_STATE LOW // Pin state indicating that filament is NOT present. #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins.
