Yes this is simple!
In marlin open your pins folder for your controller card and exchange the pin numbers for broken Z with the Pins on E1
This will change the status of E1 to work as the new Z driver and the broken driver Z will be unused it not connected.
This has worked on my controllers though it is possible that more damage was caused an this exchange may not fix the problem.
I changed my X with E1 and remarked out E1 with a different controller board.
#define X_STEP_PIN 36 //54
#define X_DIR_PIN 34 //55
#define X_ENABLE_PIN 30 //38
#ifndef X_CS_PIN
#define X_CS_PIN 44 //53
#endif
//#define E1_STEP_PIN 36
//#define E1_DIR_PIN 34
//#define E1_ENABLE_PIN 30
//#ifndef E1_CS_PIN
//#define E1_CS_PIN 44
//#endif
Edited 3 time(s). Last edit at 05/27/2022 08:59AM by Roberts_Clif.
