New Marlin configuration is restarting/resseting Arduino board June 27, 2022 07:26PM |
Re: New Marlin configuration is restarting/resseting Arduino board June 28, 2022 01:04AM |
Re: New Marlin configuration is restarting/resseting Arduino board June 28, 2022 02:24AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: New Marlin configuration is restarting/resseting Arduino board June 28, 2022 04:26AM |
Re: New Marlin configuration is restarting/resseting Arduino board June 30, 2022 01:11PM |
[email protected]
Couldn't sleep so ... just in case it's of use - here's the Ultimaker Original (1.5.7) config files converted to work with bugfix-2.1.x
I've compiled it (via Auto Build Marlin plugin for VSCode) and included the result.
Re: New Marlin configuration is restarting/resseting Arduino board June 30, 2022 01:15PM |
VDX
... this "endless reset" ist most likely caused by too low voltage ... measure the +5V at the chip - should be "oszillating" too, when the display is drawing too much power ...
Re: New Marlin configuration is restarting/resseting Arduino board June 30, 2022 05:11PM |
Re: New Marlin configuration is restarting/resseting Arduino board June 30, 2022 06:01PM |
[email protected]
Try disabling SD support. That was a cause of reset loops in some of the later Marlin releases. Maybe the problem isn't fully resolved yet.
Re: New Marlin configuration is restarting/resseting Arduino board June 30, 2022 11:14PM |
Re: New Marlin configuration is restarting/resseting Arduino board July 28, 2022 06:27PM |
[email protected]
SDSUPPORT was the correct change.
Here's another long shot. Change your thermistor(s) to 998. This sets the temperature to 25C no matter what. Every so often we see someone develop thermistor issues which results in the thermal protection kicking in and resetting the controller.
vdx
Re: New Marlin configuration is restarting/resseting Arduino board July 28, 2022 08:03PM |
cletero
[email protected]
Thanks, I will try this as well.
vdx
I finally measured this, an voltage is in fact oscillanting, around 2.5 - 3 V, so not sure where to go from there. My colleague suggest trying a new Arduino Mega, but not sure if that's the issue.
Re: New Marlin configuration is restarting/resseting Arduino board July 29, 2022 12:10AM |
Re: New Marlin configuration is restarting/resseting Arduino board August 22, 2022 10:17AM |
